Posted July 8, 20186 yr comment_552680 Something isn't right with the T/S. The turn signal handle will go up ( right turn ), but it won't go down because of the little white block for the horn, as in pic. Where do the T/S tabs hit at ? On the steering column forward of the ball bearings ? I'll find out when I put the plastic clam shell on, shouldn't I ? Thank you very much Link to comment https://www.classiczcars.com/forums/topic/60347-71-combo-switch-fitment-on-steering-column-question/ Share on other sites More sharing options...
July 8, 20186 yr comment_552681 You got the horn connection on upside down. Flip it over and all will be good. Its suppose to face to the right.Sent from my [device_name] using http://Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/60347-71-combo-switch-fitment-on-steering-column-question/#findComment-552681 Share on other sites More sharing options...
July 9, 20186 yr Author comment_552722 I have no idea how it got that way. Thank you. Link to comment https://www.classiczcars.com/forums/topic/60347-71-combo-switch-fitment-on-steering-column-question/#findComment-552722 Share on other sites More sharing options...
