July 13, 20186 yr Author comment_552964 I got the brake lights to work. Major accomplishment. I have 2 GR wires and 2 GB wires going to connector by column. Not on wiring diagram. Plus other wires not on diagram. Thank you. Link to comment https://www.classiczcars.com/forums/topic/60351-71-msa-fuse-box-question-and-blowing-fuses/?&page=2#findComment-552964 Share on other sites More sharing options...
July 13, 20186 yr comment_552965 Post photos that show the wires, connectors, and relative location clearly. Link to comment https://www.classiczcars.com/forums/topic/60351-71-msa-fuse-box-question-and-blowing-fuses/?&page=2#findComment-552965 Share on other sites More sharing options...
July 13, 20186 yr comment_552971 What about the fuse that keeps blowing? Phil Smith Link to comment https://www.classiczcars.com/forums/topic/60351-71-msa-fuse-box-question-and-blowing-fuses/?&page=2#findComment-552971 Share on other sites More sharing options...
July 13, 20186 yr Author comment_552986 I don't know what I did but it's not blowing now. On top of the combo switch, H/L module, their are 2 black wires, 1 goes to the 6 pin connector, then is connected to a GY wire and then goes to the fuse box where there are 2 wires, GL and RL going to the same pin. I thought all black wires were grounds ? Thank you very much. Link to comment https://www.classiczcars.com/forums/topic/60351-71-msa-fuse-box-question-and-blowing-fuses/?&page=2#findComment-552986 Share on other sites More sharing options...
July 14, 20186 yr Author comment_553014 Here's a pic of connector with 2 GR and 2 GB wires. It's next to steering column by the other 6 pin connector. The 1 GB wire isn't very visible. Link to comment https://www.classiczcars.com/forums/topic/60351-71-msa-fuse-box-question-and-blowing-fuses/?&page=2#findComment-553014 Share on other sites More sharing options...
July 14, 20186 yr comment_553017 I am thinking it's for the turn signals, however, I'm not 100%. There shouldn't be a blue/white wire on that connector. The blue/white should be for the wipers. Did someone do some creative wiring in the past? Link to comment https://www.classiczcars.com/forums/topic/60351-71-msa-fuse-box-question-and-blowing-fuses/?&page=2#findComment-553017 Share on other sites More sharing options...
