Posted July 17, 20186 yr comment_553242 I need to replace the rubber squeegees in the door to glass mouldings. - Does anyone know a source for the rubber (no metal)? Link to comment https://www.classiczcars.com/forums/topic/60396-has-anyone-found-a-source-and-replaced-window-squeegees/ Share on other sites More sharing options...
July 17, 20186 yr comment_553243 I bought pair from a vendor called DatsunLandSoCal several years ago. They install with metal clips (from the underside, so not visible) rather than staples and I am very satisfied with the shape and dimensions, the appearance and the installation system. They sold at the time for over $50 for the pair, so not cheap. Unfortunately, the seller seems to no longer be in business. Somewhere out there, there might be a roll of this rubber, waiting to be put to use. Where is it? Link to comment https://www.classiczcars.com/forums/topic/60396-has-anyone-found-a-source-and-replaced-window-squeegees/#findComment-553243 Share on other sites More sharing options...
July 17, 20186 yr comment_553250 Here you go: https://zcarsource.com/door-upper-molding-rubber-seal-240z-260z-280z-70-78-new I see you found my 5-year old post on my fuzzy strips install method. I installed the squeegees the same way. Jim Link to comment https://www.classiczcars.com/forums/topic/60396-has-anyone-found-a-source-and-replaced-window-squeegees/#findComment-553250 Share on other sites More sharing options...
May 30, 20195 yr comment_576568 ZCARSOURCE has them as of 5/29/2019. Link to comment https://www.classiczcars.com/forums/topic/60396-has-anyone-found-a-source-and-replaced-window-squeegees/#findComment-576568 Share on other sites More sharing options...
May 30, 20195 yr comment_576580 6 hours ago, Jughead said: ZCARSOURCE has them as of 5/29/2019. Did you see them on the website, or did you talk to someone to confirm they actually have them? I have noticed in the past they have products on their webpage they don't stock/don't ship. Link to comment https://www.classiczcars.com/forums/topic/60396-has-anyone-found-a-source-and-replaced-window-squeegees/#findComment-576580 Share on other sites More sharing options...
June 5, 20195 yr comment_576952 Both. I've received the rubber and it looks good. Anyone know how best to attached the rubber to the chrome piece? Link to comment https://www.classiczcars.com/forums/topic/60396-has-anyone-found-a-source-and-replaced-window-squeegees/#findComment-576952 Share on other sites More sharing options...
