Posted July 17, 20186 yr comment_553282 Will this transmission work in an L series swap if the bell housing /front case is changed? Couldn’t find a definitive answer anywhere. Thanks, Dean Link to comment https://www.classiczcars.com/forums/topic/60403-1981-200sx-5-speed/ Share on other sites More sharing options...
July 17, 20186 yr comment_553285 Probably. Which engine in the 200SX? Some of the transmissions have shorter tail shaft housings though. You might need a custom driveshaft. Link to comment https://www.classiczcars.com/forums/topic/60403-1981-200sx-5-speed/#findComment-553285 Share on other sites More sharing options...
July 17, 20186 yr Author comment_553288 Don’t know which engine, just know it’s from an 81. Transmission looks like the zx but bellhousing is definitely not the same. Link to comment https://www.classiczcars.com/forums/topic/60403-1981-200sx-5-speed/#findComment-553288 Share on other sites More sharing options...
July 17, 20186 yr comment_553289 Can you post a picture? I think there is another 5 speed that Nissan used on the lower power engines. My 1978 Datsun B210 had a 5 speed but I'm pretty sure it wasn't a 71B 5 speed. My vague memory is of a much smaller unit. Link to comment https://www.classiczcars.com/forums/topic/60403-1981-200sx-5-speed/#findComment-553289 Share on other sites More sharing options...
July 17, 20186 yr comment_553290 I found an old 200SX manual that I had that shows the 71B as the 200SX transmission. So if you get a Z car front case/housing it should bolt to the engine. But, as I said, it's been reported the the length might be different. So it might not be "just like" a Z car 5 speed. And, if the tail shaft housing is different the crossmember mounting points might be different, along with the exhaust system hangers. So, you could probably make it work but it might not be worth the effort. Link to comment https://www.classiczcars.com/forums/topic/60403-1981-200sx-5-speed/#findComment-553290 Share on other sites More sharing options...
July 17, 20186 yr Author comment_553291 Link to comment https://www.classiczcars.com/forums/topic/60403-1981-200sx-5-speed/#findComment-553291 Share on other sites More sharing options...
July 17, 20186 yr comment_553294 It's a 71B. I marked the two critical measurements. One to the mount, and the other for total length. Get those and somebody can provide a comparison. I have a a couple out in the garage. Link to comment https://www.classiczcars.com/forums/topic/60403-1981-200sx-5-speed/#findComment-553294 Share on other sites More sharing options...
July 17, 20186 yr Author comment_553305 16-1/2 total length to tail shaft casting and 6-5/8 to the cross member hole center. Edited July 17, 20186 yr by idoxlr8 Link to comment https://www.classiczcars.com/forums/topic/60403-1981-200sx-5-speed/#findComment-553305 Share on other sites More sharing options...
July 17, 20186 yr comment_553307 That seems to be what mine are. So with a front case swap it should work. You shouldn't have to do any extra work either, bearing swaps or grinding, since the bearings and clearances should be the same. But the ratios are more like a 280Z, not a 280ZX, apparently. The Haynes manual that I have says the ratios are 3.321, 2.077, 1.308, 1, and 0.833. So a 3.54 diff ratio would be about right. Link to comment https://www.classiczcars.com/forums/topic/60403-1981-200sx-5-speed/#findComment-553307 Share on other sites More sharing options...
July 17, 20186 yr Author comment_553310 Appreciate that and confirms what I had thought. Wide ratio but I can swap the front housing off my existing 4 speed. Thanks! Link to comment https://www.classiczcars.com/forums/topic/60403-1981-200sx-5-speed/#findComment-553310 Share on other sites More sharing options...
July 17, 20186 yr comment_553311 You will have to open up one of the shift fork holes and relocate the reverse switch boss on your four speed bell housing. I just did this with a 86 200sx tranny except I used a five speed bell housing I had laying around. Link to comment https://www.classiczcars.com/forums/topic/60403-1981-200sx-5-speed/#findComment-553311 Share on other sites More sharing options...
July 17, 20186 yr comment_553316 I think that 86 uses the 71C transmission. His is the 71B. That's the heart of the topic. Here's a link that covers some of the models and year changes. http://datsun1200.com/modules/mediawiki/index.php?title=71-series_Transmission Link to comment https://www.classiczcars.com/forums/topic/60403-1981-200sx-5-speed/#findComment-553316 Share on other sites More sharing options...
