Posted July 22, 20187 yr comment_553609 Behind the passenger side rear plastic panel there is a steel panel of almost the exact same shape covering the gas tank vapour recovery tank, does it really serve a purpose? Link to comment https://www.classiczcars.com/forums/topic/60429-steel-panel-required/ Share on other sites More sharing options...
July 22, 20187 yr comment_553612 It makes it look nicer and maybe helps keep some fumes out but I doubt thatSent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/60429-steel-panel-required/#findComment-553612 Share on other sites More sharing options...
July 22, 20187 yr comment_553616 Its not cosmetic or fumes. (It's not sealed, and you can't see it normally). I'm guessing some sort of safety agency requirement. Something like "there must be a metal layer between anything containing fuel or vapor and the occupant interior." maybe? Only other guess would be noise reduction? Link to comment https://www.classiczcars.com/forums/topic/60429-steel-panel-required/#findComment-553616 Share on other sites More sharing options...
July 22, 20187 yr comment_553618 On 7/22/2018 at 1:37 PM, Captain Obvious said: Only other guess would be noise reduction? A Canadian cure for fuel tank flatulence??? Seriously (yeah, sure), I vote for the safety aspect. I've never seen this in US spec cars, possibly a Canadian rule. Link to comment https://www.classiczcars.com/forums/topic/60429-steel-panel-required/#findComment-553618 Share on other sites More sharing options...
July 22, 20187 yr comment_553622 I've never seen that either. I would agree with Jim's assessment Link to comment https://www.classiczcars.com/forums/topic/60429-steel-panel-required/#findComment-553622 Share on other sites More sharing options...
July 22, 20187 yr comment_553628 I have one in my car too. I will put it back in and hope it aids in sound deadening. Link to comment https://www.classiczcars.com/forums/topic/60429-steel-panel-required/#findComment-553628 Share on other sites More sharing options...
July 22, 20187 yr comment_553637 I have one in my 78 280z and it’s US specSent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/60429-steel-panel-required/#findComment-553637 Share on other sites More sharing options...
July 22, 20187 yr Author comment_553655 On 7/22/2018 at 1:37 PM, Captain Obvious said: Its not cosmetic or fumes. (It's not sealed, and you can't see it normally). I'm guessing some sort of safety agency requirement. Something like "there must be a metal layer between anything containing fuel or vapor and the occupant interior." maybe? Only other guess would be noise reduction? Probably right, if I do put it back in I'll add a some dense foam between the steel panel and the vapour tank, then there will be some noise reduction. Link to comment https://www.classiczcars.com/forums/topic/60429-steel-panel-required/#findComment-553655 Share on other sites More sharing options...
July 22, 20187 yr comment_553669 On 7/22/2018 at 5:40 PM, ryanotown22 said: I have one in my 78 280z and it’s US spec Well... with one vote for a US spec car, this looks to be a 280Z thing and not a Canadian rule thing. Shows to go my lack of exposure to the intimate details on 280Z's. Link to comment https://www.classiczcars.com/forums/topic/60429-steel-panel-required/#findComment-553669 Share on other sites More sharing options...
July 23, 20187 yr comment_553682 I haven't checked my car, but my assumption is that it's not a Canadian thing and my car has one as well. On 7/22/2018 at 2:10 PM, jfa.series1 said: A Canadian cure for fuel tank flatulence??? Smells like maple syrup maybe? Link to comment https://www.classiczcars.com/forums/topic/60429-steel-panel-required/#findComment-553682 Share on other sites More sharing options...
July 23, 20187 yr comment_553684 I have one in my Fed 77' and there's one in the 78' I'm putting together so it's not just a Canadian thing. If Canadian fuel flatulence smells of maple syrup then my car needs a different diet....... Link to comment https://www.classiczcars.com/forums/topic/60429-steel-panel-required/#findComment-553684 Share on other sites More sharing options...
July 23, 20187 yr comment_553686 May be due to proximity to new speaker addition. Link to comment https://www.classiczcars.com/forums/topic/60429-steel-panel-required/#findComment-553686 Share on other sites More sharing options...
