Posted May 7, 200321 yr comment_36575 Does anyone know if Z car hubs can be redrilled for 4x100 pattern? I have a new set of 15x7 wheels, 4x100, with an offset that will work with our z-cars, that is, if I can redrill the hubs acceptably...Eric aka ZMunkey Link to comment https://www.classiczcars.com/forums/topic/6045-redrill-hubs-for-4x100/ Share on other sites More sharing options...
May 7, 200321 yr comment_36591 Why bother when you can just buy these adapters? It would cost more than these cost to have your hubs re-drilled....http://www.modern-motorsports.com/catalog/product_info.php?products_id=6&PHPSESSID=1b009780367981439bff71e97991ae24 Link to comment https://www.classiczcars.com/forums/topic/6045-redrill-hubs-for-4x100/#findComment-36591 Share on other sites More sharing options...
May 8, 200321 yr Author comment_36663 Because I already have wheels with the proper offset! I don't need spacers, have no room for spacers, don't want spacers. These are not 40mm offset Honda/Nissan/VW wheels.ZMunkey Link to comment https://www.classiczcars.com/forums/topic/6045-redrill-hubs-for-4x100/#findComment-36663 Share on other sites More sharing options...
May 8, 200321 yr comment_36669 Well, OK, but... They do make these spacers in custom thinknesses if you are using non-Honda spec offset wheels. http://www.modern-motorsports.com/catalog/mm_faq.php?PHPSESSID=1b009780367981439bff71e97991ae24 I think the problem would be that to do the job correctly re-drilling the hubs, you would need to get 280 hubs and stub axles to be able to have enough material to re-drill 4 new holes in the flange in the correct spacing you need. If you were to use the 240 hubs, they would need to weld and re-drill the existing stud mounting holes, which would end up being as strong as they would need to be, but it would cost you quite a bit in labor and machine costs. Try contacting Modern Motorsports and see what they can come up with, or ask them if they could do your hubs and what their opinion would be... I'm not a machinist, but, if you look at the differences between the 240 and 280 hubs, perhaps you'll understand what I'm trying to explain. The 280 hub flange is the same thickness and is round, while the 240 hub flange has 4 "ears" that have raised pads that the wheel mounts against. Link to comment https://www.classiczcars.com/forums/topic/6045-redrill-hubs-for-4x100/#findComment-36669 Share on other sites More sharing options...
June 14, 200519 yr comment_127390 What about redrilling the 280z hubs to suit a 5by114.3 PCD? on the rotor side and the wheel side???So i can fit different rotors easier and more common wheels? Link to comment https://www.classiczcars.com/forums/topic/6045-redrill-hubs-for-4x100/#findComment-127390 Share on other sites More sharing options...
June 14, 200519 yr comment_127400 what are those 'new wheels' off of? or what are they made to fit? 4x100 with correct offset are ultra rare. Link to comment https://www.classiczcars.com/forums/topic/6045-redrill-hubs-for-4x100/#findComment-127400 Share on other sites More sharing options...
June 14, 200519 yr comment_127411 Well, OK, but...They do make these spacers in custom thinknesses if you are using non-Honda spec offset wheels. They would have to be very thin spacers, like 0mm to retain the correct offset. Link to comment https://www.classiczcars.com/forums/topic/6045-redrill-hubs-for-4x100/#findComment-127411 Share on other sites More sharing options...
June 14, 200519 yr comment_127412 What aboout A NEGATIVE OFFSET SPACER-or would that be like a portable hole...Maybe if you mixed spam and vegimite...Will Link to comment https://www.classiczcars.com/forums/topic/6045-redrill-hubs-for-4x100/#findComment-127412 Share on other sites More sharing options...
June 15, 200519 yr comment_127483 have you thought about using hubs off a car with 4 x 100 studs on the z strut thats what i did with my rx4 used datsun hubs on mazda struts only had to change bearings luckicly the hubs had bearing mounts in same place the re drilled back axles to suit might be worth a look i know other guys who have used for hubs on datsun struts to get ventliated discs i just bought black discs and mounted them to datsun hubs on my zedmick Link to comment https://www.classiczcars.com/forums/topic/6045-redrill-hubs-for-4x100/#findComment-127483 Share on other sites More sharing options...
June 15, 200519 yr comment_127485 What aboout A NEGATIVE OFFSET SPACERNo...I don't think that'll work. THOSE spacers have the bolts facing the INSIDE. Link to comment https://www.classiczcars.com/forums/topic/6045-redrill-hubs-for-4x100/#findComment-127485 Share on other sites More sharing options...
