November 22, 20186 yr comment_562205 That explains he rust in my front fenders. I wonder where the Datsun designers thought the water would go...? Link to comment https://www.classiczcars.com/forums/topic/60460-where-does-water-go-around-wipers-below-windshield/?&page=2#findComment-562205 Share on other sites More sharing options...
November 24, 20186 yr comment_562254 On 11/22/2018 at 11:49 AM, Jughead said: That explains he rust in my front fenders. I wonder where the Datsun designers thought the water would go...? If it were restricted to water, it would be fine piddling out behind the fender, but inevitably leaves and pine needles and debris goes down the drains and end up packed behind the fender at the bottom. This soggy mess trapping moisture in there full time is source of rust. There is a mod discussed here where you add a 90 deg elbow and an addition hose to the cowl drain hose that runs all the way down and empties into the wheel well. Pokes out where that little rubber flat is located at the bottom of the fender/inner wheel well plate is. This makes sure WHATEVER comes down that hose ends up in free air behind the wheel, not trapped behind the fender. 1.25 elbow and hose I think is the size. Link to comment https://www.classiczcars.com/forums/topic/60460-where-does-water-go-around-wipers-below-windshield/?&page=2#findComment-562254 Share on other sites More sharing options...
