January 10, 20214 yr Author comment_614177 On 1/6/2021 at 2:43 AM, BAS_DXB said: Totally dig the Hulky Green color with the bronze rims ! Super nice job done, definitely some inspiration for my own project ! Thanks for sharing all this ! Thank you! Should be on the road within the next month. Just finishing up the glass, rubber and some misc. work! Link to comment https://www.classiczcars.com/forums/topic/60500-california-1978-datsun-280z-restomod/?&page=15#findComment-614177 Share on other sites More sharing options...
March 29, 20214 yr Author comment_618778 Car is almost there. Fuel system done, exhaust done, glass back in, rear coilovers fitted and ride height dialled in. Dash installed. Dapper Lighting headlights and JDM 240z taillights installed. Alignment done. New injectors, connectors and other misc. wiring under the hood to fix some rough running - cylinder 3 had an injector stuck open which flooded everything. Decided to replace all 6 for peace of mind. Edited March 30, 20214 yr by Kevin McSweeney Link to comment https://www.classiczcars.com/forums/topic/60500-california-1978-datsun-280z-restomod/?&page=15#findComment-618778 Share on other sites More sharing options...
March 29, 20214 yr Author comment_618781 She's running good, but the temperature did start creeping up while idling for a while. Will need to run for a little longer each time before driving very far. 0f62388b02e749a7a8652b859a41b096.MOV Link to comment https://www.classiczcars.com/forums/topic/60500-california-1978-datsun-280z-restomod/?&page=15#findComment-618781 Share on other sites More sharing options...
March 29, 20214 yr comment_618782 Looks spectacular! Link to comment https://www.classiczcars.com/forums/topic/60500-california-1978-datsun-280z-restomod/?&page=15#findComment-618782 Share on other sites More sharing options...
March 29, 20214 yr Author comment_618783 10 minutes ago, wheee! said: Looks spectacular! Thank you! Very happy with how she looks! Link to comment https://www.classiczcars.com/forums/topic/60500-california-1978-datsun-280z-restomod/?&page=15#findComment-618783 Share on other sites More sharing options...
March 29, 20214 yr comment_618792 Agreed. Looks fantastic! Link to comment https://www.classiczcars.com/forums/topic/60500-california-1978-datsun-280z-restomod/?&page=15#findComment-618792 Share on other sites More sharing options...
March 30, 20214 yr comment_618902 Valve cover came back from powder coating today. Very happy with the finished product.Dang that looks good! I want to do that to mine, did you just drop it off at the powder coat shop to get that done? Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/60500-california-1978-datsun-280z-restomod/?&page=15#findComment-618902 Share on other sites More sharing options...
March 30, 20214 yr Author comment_618911 2 hours ago, Oilking53 said: Dang that looks good! I want to do that to mine, did you just drop it off at the powder coat shop to get that done? Sent from my iPhone using Tapatalk I did, but I know the guy pretty well, so we talked a while about what I wanted. It's a wrinkle coat and we just masked up the lettering. Link to comment https://www.classiczcars.com/forums/topic/60500-california-1978-datsun-280z-restomod/?&page=15#findComment-618911 Share on other sites More sharing options...
April 1, 20214 yr comment_619051 On 3/28/2021 at 5:14 PM, Kevin McSweeney said: Car is almost there. Fuel system done, exhaust done, glass back in, rear coilovers fitted and ride height dialled in. Dash installed. Dapper Lighting headlights and JDM 240z taillights installed. Alignment done. New injectors, connectors and other misc. wiring under the hood to fix some rough running - cylinder 3 had an injector stuck open which flooded everything. Decided to replace all 6 for peace of mind. Looks very nice Kevin. I gotta ask. You filled in the rear side maker light openings, but left the front ones open. How come? Link to comment https://www.classiczcars.com/forums/topic/60500-california-1978-datsun-280z-restomod/?&page=15#findComment-619051 Share on other sites More sharing options...
April 1, 20214 yr Author comment_619052 1 minute ago, Racer X said: Looks very nice Kevin. I gotta ask. You filled in the rear side maker light openings, but left the front ones open. How come? 2 reasons: 1. Because that's how the JDM cars came and 2. Because I prefer how it looks without the rears. Link to comment https://www.classiczcars.com/forums/topic/60500-california-1978-datsun-280z-restomod/?&page=15#findComment-619052 Share on other sites More sharing options...
April 1, 20214 yr Author comment_619057 The next thing I need to get done is the wiring of the tail lights and license plate lights. As you can see I have swapped the 280z lights for JDM 240z lights. I have the original 280z tail light harnesses, and I need to get them wired and working correctly. I know there are several write ups on the physical conversion of the lights, but I can't find any on the wiring. Below are a couple of photographs of the current wiring situation. I'm not good at wiring, don't mind admitting it. So looking for some help here. Also for those wondering, yes I will be cleaning up and painting the patch panels that cover the opening for 280z reverse light and the side markers. Link to comment https://www.classiczcars.com/forums/topic/60500-california-1978-datsun-280z-restomod/?&page=15#findComment-619057 Share on other sites More sharing options...
April 1, 20214 yr comment_619059 1 hour ago, Kevin McSweeney said: The next thing I need to get done is the wiring of the tail lights and license plate lights. As you can see I have swapped the 280z lights for JDM 240z lights. I have the original 280z tail light harnesses, and I need to get them wired and working correctly. I know there are several write ups on the physical conversion of the lights, but I can't find any on the wiring. Below are a couple of photographs of the current wiring situation. I'm not good at wiring, don't mind admitting it. So looking for some help here. Also for those wondering, yes I will be cleaning up and painting the patch panels that cover the opening for 280z reverse light and the side markers. I would get the connectors and wire terminals from that company that has the correct OEM parts, and make up a jumper pigtail for each side. Link to comment https://www.classiczcars.com/forums/topic/60500-california-1978-datsun-280z-restomod/?&page=15#findComment-619059 Share on other sites More sharing options...
