Email logins are now active ×
7" brake booster repair and restoration
Patcon
I thought I would post this up here instead of burying it in my build thread.
Does any one have ideas on how to bench test a brake booster? I have an assortment of 5 or so small boosters. I would like to bench test them to see if any of them are good. Then restore the best candidate
Thoughts?
18 minutes ago, 240260280 said:
I just did this.  Put a mityvac tool with a gauge on the booster's port then draw 15" vacuum.  See how long it holds. Also with the vacuum at 15", you can slide the push rod in and out to see if the shaft to seal leaks under simulated operation.
I have that tool and that was my first thought. I assume you blanked off the master cylinder port? Did it take forever to draw the 15" of vacuum? You were moving the brake pedal clevis looking for leaks, correct?
It is easy to do.  Just connect the mityvac to the port on the booster and draw vacuum.  It just takes ~ 30sec to pull 15".
There are adapters in the kit to connect larger diameter vinyl tubing to the smaller tubing on the gun.
Pressing the clevis will release the vacuum.  It does not really test much apart from checking normal functioning.
The two main tests are:
1. [Basic Leak Test] Will the booster hold vacuum for 10min with the rod in relaxed position.
2. [Rod to Rubber Seal check]  Will the booster hold vacuum as the rod is manually pulled out a couple of inches and returned. Pitting in the rod will leak air.
You may have to move a rod seal, lubricate a seal, or even sand down a rod to make one work nicely.
I connected mine up to my vacuum pump. Used a little valve cracked a little as a regulator so I didn't suck the booster down to absolute zero.  LOL
You don't have to blank off the master cylinder port. The rubber vacuum seal on the output shaft should keep the vacuum in the clamshell.
Well evidently, I have 5 used boosters and none of them will hold a vacuum. I even blanked off the MC side of the most promising looking one and nothing,
I spent about an hour emailing companies all over the US to see if I can find someone that can rebuild the little booster without forfeiting a valuable body part...we'll see.
If they won't hold vacuum (even with the M/C hole sealed off), then there is probably an internal leak. Hole in the diaphragm or the poppet valve seal is leaking. If that's the case, when you try to draw a vacuum on it (or in your case... pull air through it), you should be able to hear air entering in the assy at the pedal push rod. Through the little felt filter thingie.
Other possibility of not being able to hold a vacuum is that it's leaking at the seam between the two sections of the clamshell where the diaphragm is pinched, but you don't hear much about that happening. it's usually something internal.
Please make sure you let us know what you turn up for rebuild options and/or parts!
240260280 posted a detailed, DIY mastervac rebuild article on the old AtlanticZ website several years ago.  Have you seen this?  (I can send you a copy).  He used RTV sealant to repair the diaphragm -- apparently with good results.  My guess (valued at 2 cents) is that 95% of the vacuum failures are due to cracking of the diaphragm, rather than failure of the poppet valve.  The extent to diaphragm issues are accompanied by leakage from a corroded pushrod is probably related to whether the car lived in the salt-belt or near an ocean.  According to 240260280, the pushrod problem can be somewhat easily remedied.
I have seen some of that. I have also attempted that kind of repair with mixed results. We really just need to find a source for the diaphragms then we could repair our own
IIRC, Steve Nix took a pass on replicating this piece because it's a safety-related item and would expose him to liability in that one failed in service.  Other low-volume parts casters will probably feel the same way.  The big parts rebuilding operations seem to have access to a source (although perhaps only because they purchased in volume from Nissan Service Parts years ago when the Z's were still 'current' and are now just working down through their inventory).  Seems questionable whether a rebuilder like Cardone would be willing to sell just the diaphragms -- even in a lot of a couple of hundred -- because it would be undercutting their primary business.  Still, maybe somebody like zcardepot.com might be willing to approach Cardone's business office with just such a proposition ("Sell us a hundred of the diaphragms and we'll carry your full rebuilt units in our catalog, too.')
  • Who's Online   1 Member, 0 Anonymous, 619 Guests (See full list)
