front suspension and tire clearance problem
newbzee
You should to pull the other side to check it too. You have to replace both ball joints anyway. If that tube was bent in an accident you need to see what other damage happened. I've seen a lot of damage to our Z race cars but the strut tubes have never bent. Check your upper and lower frames, strut towers, etc. for any damage.
Did the tire rub when you started this project? If not, why does it now?
I might have a strut assy. Left side?
Chuck
Let me provide some history so we all have them same baseline.  I was finishing up a project (1971 Porsche 911) and was looking for another project.  My Wife said she would only agree if it were a 240z because that was her HS car.  I found this car for $300.  A kid bought it as a project and it was too much.  The car ran and moved under it's own power but was not in any condition to drive.  I think I've welded more metal into this car than it came with.  The entire car was disassembled and new floors, floor rails, and front frame rails welded in.  I'm very sure the car had damage to that side based on these efforts.  I used data points from the FSM when fixing the car so it's pretty straight.  Perfect, no, but pretty straight.  So, seeing this doesn't surprise me, just annoys me because I missed it, but thats part of having a project.  Maybe it was a hidden problem and the car was out of wack and it's showing up now after making repairs?  I'm not sure , I'm definitely going to pull the other side apart but I have a small shop area and at this point it doesn't effect repairing this side.  I've had the entire front suspension and cross member out with the engine, and everything went back in easily after repairs so I'm hopeful this is the last problem from what ever happened.
Yes Chuck, Front Left side.
The way that tube is used with today's shock inserts is different from how Nissan designed it to be used.  I've had the thought a person could drill that tube pretty severely for weight reduction, because it's role with a shock insert is changed to providing compression on the shock insert.  When you have the insert in and the gland nut tight, the assembly is a double wall tube, with the inner wall compressed and the outer wall under tension.
If you can figure out where it bent or if the casting is deformed at the base you'd have a better idea of if it can be fixed.  Replace it if you can find one but don't rule out fixing what you have.  Look at some of the "coilover" setups out there and you'll see that people do all kinds of things to these strut tubes, from no basis in education or experience.  And they seem to survive.  Not referring to you and Sakura Garage cg, just saying that the problem is not as complex as it seems.  It's just a metal tube that needs to be perpendicular to the casting base.  The loads it sees are not enormous and the shock insert adds strength.
If the straightening effort doesn't work you won't have lost anything.
Had a very similar thought this morning after looking at a couple of coiler sites.  I was going to see what I can come up with this afternoon, with the same understanding that I really have nothing to loose at this point.  If the bend is high enough I could sleeve it, if too low, I could add a gusset.
Ok so heres some additional findings.  I took the strut apart and it already had an inert.  I think the reason I was able to get some clearance earlier is because the gland nut wasn't very tight and the insert had a little free play.  I've attached another picture and it appears the bend is at the base, not in the base, just above the collar.  So how to straighten?  The power of Hercules is not within me and there is no good way to leverage the spindle/wheel area.  I could get leverage at the tube by putting the inset back in or a pipe, no clue on the over part.  Another thought would be to use the tree falling approach and put a relief cut on the side I want to bend towards which would close the cut if I can bend it and provide an easier weld.  Someone managed to get it bend this far into shape so it has to be possible.
Buy...
Another...
Strut...
Housing!!!!
C'mon man!!!   LOL   And I thought I spent a ridiculous amount of time on things that I never should have done in the first place.
It was tweaked. Enough to exceed the plastic deformation rating of the material. It'll never be the same again. Buy another strut housing!!!
You...
Are...
Missing...
The...
Point...
CO
Really surprising since you're the guy that likes to fix broken things.  Replacing things without understanding how they work makes me cringe.  If you understand it and you can make it do what it's supposed to do, then fixing it is fine.  Replacing without understanding is kind of lazy, if you have the time to learn.  Surprised at your comment, and the way you made it.  It has the period!, game-set-match! tone.  Eewww...
LOL. Yeah, I know. Far be it for me to suggest that someone else is doing something like that.
In my defense, however... My understanding is that everyone seems to be in agreement that it's bent. I thought the "understanding" part of the problem was already over and we had moved to the "what to do about it?" part.
If that's not the case, and a definitive cause for the lack of clearance to the tire has not yet figured out yet, then carry on!     LOL
However, if that strut tube has been bent, then my humble opinion is that I think replacing instead of trying to bend back is the proper course of action.
It's just the outer case of a shock absorber.  The loads are small, relatively speaking.  The rest of the parts take up the extreme loads.
We are in the "what to do about it" part.  If you can make a case for how it might fail after a fix attempt that would be informative.  I think it will be about like it was before after bending back, probably stiffer.  Barring another curb shot, it will be fine.
Hey I really appreciate everyones input and if buying a replacement is the answer I'm fine with that but other than time, messing with this part only give me knowledge.  So here is where I'm at, I got the house fairly perpendicular but had to made 2 relief cuts to do it.  The insert still fits but is a little snug near those cuts.  So realistically I would need one more a little lower to help the rest of the way.  Welding these up is not an issue.  The main issue was the tweak was only about an inch above where the tube goes into the spindle.  Once I cleaned it up and put a straight edge flat to that area it was easy to see.  So, thoughts?
Put the shock in and see how it all fits with the gland nut clamped down.  You might have been able to make one small cut and had it all correct once it was clamped together.  Didn't realize you were going with big cuts like that.
You're kind of at the point where only your opinion matters.  If somebody can point out a safety issue they should, otherwise it's aesthetics.
A thought popped in to my head before - if the part was easily replaceable, this conversation probably wouldn't be happening.  But I'll bet your car could be down quite a while if you wait for a front strut to show up somewhere.  Beside the cost.  Good luck.
