Posted August 26, 20186 yr comment_556229 Hey guys the whole inspection thing has pumped the brakes on my progress. I've found a local chassis, clean reggy decent shape. Actually better than mine in some spots and worse in others haha, there's a balance. Anyhow, what's the difference chassis wide between my 71 240(and all attaching parts) vs a 74 260. When the car is complete will there be visual differences outside. All my badging is new and 240z so I am kinda concerned ill have issues ahead. Will my 71 dash board and windshield fit hood rear deck kid etc. Thanks EH Sent from my SM-N950W using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/60655-possible-fresh-chassis-for-build-thoughts/ Share on other sites More sharing options...
August 26, 20186 yr comment_556230 Too dissimilar to be straight swap for parts. Door cards, interior mounts, bumpers probably, etc etc. Link to comment https://www.classiczcars.com/forums/topic/60655-possible-fresh-chassis-for-build-thoughts/#findComment-556230 Share on other sites More sharing options...
August 26, 20186 yr comment_556235 It's my understanding that many things don't transfer well chassis to chassis. I believe even the window mechanisms are a little different. I suspect the dash might be too. Although you're pretty good at fab work. But if I am going to add all that work, the chassis needs to be pretty good to offset it. Link to comment https://www.classiczcars.com/forums/topic/60655-possible-fresh-chassis-for-build-thoughts/#findComment-556235 Share on other sites More sharing options...
August 26, 20186 yr Author comment_556236 Turns out his car faces the same issue haha. Out of province inspection required. Oh well, ill keep browsing. And go stare at mine this afternoon. Contemplate the plan of attack. Sent from my SM-N950W using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/60655-possible-fresh-chassis-for-build-thoughts/#findComment-556236 Share on other sites More sharing options...
