1970 HLS30-06521 Re-Restoration
CanTechZ
Yesterday I picked up the rear rotisserie brackets from my fabricator (in the tacked state) and this morning I was able to do a test fit to check the angle for the diff mount extensions. They fit good, so they can now be welded up as is. While they were attached I also did a squareness check and found that the left bumper mount was was note quite parallel with the right. A 1/8 inch shim (2 washers) between the far left bolt and the new bracket took care of the issue, so I will have no problems with alignment when assembling on the main rotisserie end support. Hopefully next weekend I will be able to get the body onto the rotisserie.
The red arrow in this next pic shows where I need the 1/8" shim.
Edited by CanTechZ
  • Like 4
2 hours ago, grannyknot said:
That 5.5" was with the hatch, hood and doors removed and I was free wheeling the spin, yours is probably bit top heavy but not a problem as the gears are taking the weight.   Looks great.
Thanks, and I totally agree that it will be more balanced with those items removed. They will come off eventually, just doesn't make sense for me to do it with the limited space I have.
  • 5 months later...
