Posted September 20, 20186 yr comment_557815 Hi guys, I am assembling the seat belts and noticed the belt that fastened to the top seems to be missing something. To me if I tighten the bolt down it is just going to crush the plastic. Am I missing something? Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/60792-seat-belt/ Share on other sites More sharing options...
September 20, 20186 yr comment_557824 On my 7'70 the bolt does tighten onto the plastic with a stack steel and plastic washers like in these pictures. My interior is currently out but I believe the order of washers is correct. Even when the bolt is tight I can swivel the metal part of the seatbelt with some resistance. Hope this helps. Link to comment https://www.classiczcars.com/forums/topic/60792-seat-belt/#findComment-557824 Share on other sites More sharing options...
September 20, 20186 yr Author comment_557825 Yep this helps. Now just to locate a plastic washer like that :) Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/60792-seat-belt/#findComment-557825 Share on other sites More sharing options...
September 20, 20186 yr comment_557830 Let me know if you would like dims for that washer. I have not re-assembled it yet. Link to comment https://www.classiczcars.com/forums/topic/60792-seat-belt/#findComment-557830 Share on other sites More sharing options...
September 20, 20186 yr Author comment_557856 Measuring it would help a lot thank you Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/60792-seat-belt/#findComment-557856 Share on other sites More sharing options...
September 21, 20186 yr comment_557869 When I measured the plastic washers and bolt I learned that the bolt is not metric, it's 7/16-20 UNF. Probably to meet federal safety regulations at the time. Also there are two plastic washers, the they both have centering pilot that goes into the metal body mounting bracket and the body side washer is threaded, 7/16-20 UNF. Here is a drawing, best I could measure, and a couple of pictures. The two steel washers are 24mm OD x 11.5mm ID x 2.3mm thick and the 7/16-20 UNF bolt is 1.7" long. The reddish fibre washer is about 20mm OD x 11mm ID x 0.6mm thick and has internal serrations. These parts are from my 7'70 so they would come with a safety belt set, part number 86800-E4100 that was used up to 11,71 SAFETY BELT WASHERS - 86800-E4100.pdf Link to comment https://www.classiczcars.com/forums/topic/60792-seat-belt/#findComment-557869 Share on other sites More sharing options...
September 24, 20186 yr Author comment_558092 Thank you the info is very appreciated Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/60792-seat-belt/#findComment-558092 Share on other sites More sharing options...
