Posted September 21, 20186 yr comment_557881 Hey gang, I have a bunch of parts available - some new, some NOS, some refurbished, and some just plain used. Too many to photograph and list individually. Check out the attached PDF and get back to me if there is something you're interested in. Rather than clutter the forum, I suggest a PM or email (listed on the bottom of the PDF). Note that shipping is extra at actual cost on all items. Jim Parts List 09-21-18.pdf Link to comment https://www.classiczcars.com/forums/topic/60799-nosnew-refurbished-used-partz/ Share on other sites More sharing options...
September 21, 20186 yr comment_557883 pm sent I want the harmonic balancer and wiper frames. Edited September 21, 20186 yr by rcb280z Link to comment https://www.classiczcars.com/forums/topic/60799-nosnew-refurbished-used-partz/#findComment-557883 Share on other sites More sharing options...
September 21, 20186 yr Author comment_557886 A couple of responses, thanks. Please include a shipping address if you are contacting me, will need it to get actual postage costs on most items. Link to comment https://www.classiczcars.com/forums/topic/60799-nosnew-refurbished-used-partz/#findComment-557886 Share on other sites More sharing options...
September 24, 20186 yr Author comment_558108 Sold: Harmonic Balancer, NOS Steering Coupler, Wiper Blade Frames, Crossmember Plates, Sidemarker Boots, Series 1 Panel, Fuel Pump Plate, Differential Mount, Inspection Lids. Link to comment https://www.classiczcars.com/forums/topic/60799-nosnew-refurbished-used-partz/#findComment-558108 Share on other sites More sharing options...
September 25, 20186 yr comment_558158 Do you have a pic of one of the re-plated fuel rails? I would like to purchase along with some other smalls that are replated. Thanks Link to comment https://www.classiczcars.com/forums/topic/60799-nosnew-refurbished-used-partz/#findComment-558158 Share on other sites More sharing options...
September 25, 20186 yr Author comment_558165 On 9/25/2018 at 4:08 PM, Jaymanbikes said: Do you have a pic of one of the re-plated fuel rails? I would like to purchase along with some other smalls that are replated. Thanks Not yet but will get to work on that and get it posted soon. Thanks. Link to comment https://www.classiczcars.com/forums/topic/60799-nosnew-refurbished-used-partz/#findComment-558165 Share on other sites More sharing options...
September 25, 20186 yr Author comment_558166 @Jaymanbikes Hers are pics of both rails - essentially the same, everything nice and straight. Note that the rail in the back has the rear port at an angle. I could not find signs that it had been bent by a PO so I left it alone (if it ain't broke, don't fix it). Let me know if you need more info. Link to comment https://www.classiczcars.com/forums/topic/60799-nosnew-refurbished-used-partz/#findComment-558166 Share on other sites More sharing options...
September 25, 20186 yr comment_558168 On 9/25/2018 at 7:54 PM, jfa.series1 said: @Jaymanbikes Hers are pics of both rails - essentially the same, everything nice and straight. Note that the rail in the back has the rear port at an angle. I could not find signs that it had been bent by a PO so I left it alone (if it ain't broke, don't fix it). Let me know if you need more info. Will send you a PM Link to comment https://www.classiczcars.com/forums/topic/60799-nosnew-refurbished-used-partz/#findComment-558168 Share on other sites More sharing options...
September 26, 20186 yr Author comment_558248 Sold: Fuel linkage X 2, battery hold-down, cam cover, plug wire holder, 240Z coil bracket, fuel rail. Link to comment https://www.classiczcars.com/forums/topic/60799-nosnew-refurbished-used-partz/#findComment-558248 Share on other sites More sharing options...
