September 23, 20186 yr comment_557967 Third to last post here has pictures of my original 1976 rocker arms. They have the trapezoid. http://forums.hybridz.org/topic/118926-engine-woes-read-on-if-you-dare/?tab=comments#comment-1122036 Here's one. Edited September 23, 20186 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/60809-my-rockers-seem-to-be-a-little-off-or-im-off-my-rockers/?&page=2#findComment-557967 Share on other sites More sharing options...
September 24, 20186 yr Author comment_557995 After going through a couple hundred, there are only two types of markings. The ones with the Trapezoid always have a single letter on the opposite side, and a variety of numbers and dots next to the trapezoid. The ones that start with S have NOTHING on the other side. I can't see any structural or size differences between the two types other than the markings. Given all the stock engines I've harvested them from, I guessing they are ALL Nissan rockers. Not exactly a statistically rigorous study, but a decent sample size. I do remember a couple of points from a variety of threads on hybridz about rockers. The first point was that Delta didn't always do it right so check every one for even parallel grinding. The second point was that there seems to be a bit of variety in overall rocker arm lengths. I don't remember if they measured the actual ball center to lash pad contact points for consistency but the overall castings can vary. Try to use a set of same-ish length ones if you can of course. Edited September 24, 20186 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/60809-my-rockers-seem-to-be-a-little-off-or-im-off-my-rockers/?&page=2#findComment-557995 Share on other sites More sharing options...
September 24, 20186 yr comment_558019 I know the buyer appreciates all this pre-sale inspection and maintenance....[emoji6] Link to comment https://www.classiczcars.com/forums/topic/60809-my-rockers-seem-to-be-a-little-off-or-im-off-my-rockers/?&page=2#findComment-558019 Share on other sites More sharing options...
September 24, 20186 yr comment_558032 An optimistic spin would be: the craters hold more oil ? You helped me with a problem with Delta ground cam and rockers that ate each other on Dr 240z's 240z Link to comment https://www.classiczcars.com/forums/topic/60809-my-rockers-seem-to-be-a-little-off-or-im-off-my-rockers/?&page=2#findComment-558032 Share on other sites More sharing options...
September 24, 20186 yr comment_558081 14 hours ago, wheee! said: I know the buyer appreciates all this pre-sale inspection and maintenance.... So we now know where your getting your stroker from. Link to comment https://www.classiczcars.com/forums/topic/60809-my-rockers-seem-to-be-a-little-off-or-im-off-my-rockers/?&page=2#findComment-558081 Share on other sites More sharing options...
September 24, 20186 yr comment_558090 So we now know where your getting your stroker from.Whaaaa? Who told you that? [emoji51] Link to comment https://www.classiczcars.com/forums/topic/60809-my-rockers-seem-to-be-a-little-off-or-im-off-my-rockers/?&page=2#findComment-558090 Share on other sites More sharing options...
October 1, 20186 yr comment_558584 So I asked a couple of my mechanics at work to have a look at the rocker pics and they are convinced that the cause of this pitting is due to the engine not being run often enough! The oil gets up to the valve train, sits and slowly drips back down to the engine. The rockers eventually start pitting around the oil spots (not on the part of the pads that are under contact with the valves), and the next time it is started, the corroded metal falls off into the engine and probably into the oil filter. Basically they are saying the engine needs to be run and used more often to avoid this happening. Neither of them saw this is having any real effect on the engine as long as the oil gets changed regularly. This is good to know! Link to comment https://www.classiczcars.com/forums/topic/60809-my-rockers-seem-to-be-a-little-off-or-im-off-my-rockers/?&page=2#findComment-558584 Share on other sites More sharing options...
October 1, 20186 yr Author comment_558602 That sounds like a possible contributing factor. The car gets used for big trips and very little for day to day use. It sits a lot. I had another member discuss the possibility of acid buildup due to non-use of a PCV system but I've always had a working PCV system on the car, either with triples or with SU's and I change the oil very often, like every 2000km. But this damage appears corrosive in nature, not mechanical. I use Shell Rotella Diesel oil. Maybe I should have used synthetic all along. Link to comment https://www.classiczcars.com/forums/topic/60809-my-rockers-seem-to-be-a-little-off-or-im-off-my-rockers/?&page=2#findComment-558602 Share on other sites More sharing options...
October 1, 20186 yr comment_558604 I think the lesson here is we all need to drive our cars more! Especially in the frozen wasteland of the north....! I use AMSoil 5W30 full synthetic in the 370, but now I may be doing the same in the 280Z (or should I say 310Z)! Link to comment https://www.classiczcars.com/forums/topic/60809-my-rockers-seem-to-be-a-little-off-or-im-off-my-rockers/?&page=2#findComment-558604 Share on other sites More sharing options...
October 1, 20186 yr comment_558610 The eroded patches seem to be more on the passenger side of the pad where the pressure is greatest and the lift starts. Link to comment https://www.classiczcars.com/forums/topic/60809-my-rockers-seem-to-be-a-little-off-or-im-off-my-rockers/?&page=2#findComment-558610 Share on other sites More sharing options...
November 3, 20186 yr Author comment_560928 Delta Cam's is a wonderful business. Ignoring the fact that postal service delivery took 20 days to get there and back, they turned around 132 rocker regrinds in 48 hours (once they got there...) Every one looks like the 12 randomly selected rockers below. They look like they have some kind of coating on them, applied everywhere. Hardening process or the result of a polishing or tumbling step to make them look pretty? I suppose I could just ask... Link to comment https://www.classiczcars.com/forums/topic/60809-my-rockers-seem-to-be-a-little-off-or-im-off-my-rockers/?&page=2#findComment-560928 Share on other sites More sharing options...
November 3, 20186 yr comment_560930 Oooooo... my precious...!Dibs on 12....! Link to comment https://www.classiczcars.com/forums/topic/60809-my-rockers-seem-to-be-a-little-off-or-im-off-my-rockers/?&page=2#findComment-560930 Share on other sites More sharing options...
