Slowly starting to put things together.  Today I got the head lights and covers on along with the side markers.  Still waiting on the headliner from MSA and the correct front valance that will need to go to the painter
The car originally had a type 1 FRP airdam. I decided I wanted a stock valance and possibly add the Euro style front spoiler.  It was a last minute decision so I purchased one off EBay.  Had it straightened and painted only to find out that the center section was the wrong one.  I believe this is the 73 and up with shorter brackets..I then purchased a brand new re-pop, which are really super nice quality BTW and mocked it up to make sure it’s going to properly fit.
I used color chips epoxy and clear coat for my shop floor. It is resistant to almost all thinners. I had some gasoline varnish stain it in one area when it sat for several years. I have scratched it in places. Like dragging a transmission. The most important issue is getting the concrete clean, acid etching properly and neutralizing really, really well. Cody has also burned some areas from welding on the floor :angry: but if the floor isn't abused, like my floor, I believe it would hold up really well. The color chips epoxy is a high solids epoxy and the clear coat seals the color chips in so the floor is smoother.
2 hours ago, 7tooZ said:
@Jaymanbikes looks like you have an epoxy floor in the garage. I am trying to decide what to put on mine. Which brand did you ? Would you recommend it?  How is the durability?
