i have a -71B conversion in a MGB - i need an adapter to connect the ZX slotted output spindle to a "common" square-cable angle adapter
- i think the one in there might have been made by cutting the end off an old ZX cable - it has twisted off;
it appears that the ZX cable end was "screwed" into the slot fitting since the end bit i can see has a couple "threads" on it
UPDATE - the "threads" are just twisted metal of the 3/32 "key" where it broke - i got the other piece out of the slot adapter by drilling it
- i will need to find that slot-adaper & a new 3/32 key
any ideas ? - any source for such a piece?
FOUND this -   Stewart Warner Performance Speedometer Cable Sender Adapter 82625 - same 0.187 dia as the nissan part - at SummitRacing
Edited by emoze
update
