Spark plug gap with Mallory LED ignition module and coil
Jeff Berk
I'm playing around with a new (for me) diagnostic oscilloscope and I think I'm pulling too many kV's on the secondary wires. One potential cause appears to be related to too much resistance somewhere. The plug and coil wires test out OK (they are NGK's). The plugs were just cleaned and gap checked. I started wondering if I need to set the gaps smaller than the 0.8 - 0.9 to decrease the kV before arcing.
The oscilloscope traces are here if you are interested:
https://www.garagejournal.com/forum/showthread.php?t=404459
Edit - I just saw that you're using the gap recommended for points.
Can't see the traces without becoming a member of the other site.
What gap are you running?  The Mallory Unilite is not a "high energy" ignition system.  It is electronic but runs the same plug gap as a points setup.
http://documents.holley.com/mallory_instructions_unilite_distributor_37_38_45_47.pdf
Edited by Zed Head
Are you running resistor plugs with resistor wires?
I'm no expert.  And I can't really tell which wires you mean are the secondary wires, or what "pulling kilovolts" means.
Anyway, the oscilloscope traces would be interesting if you could paste them in over here.  Pretty sure that some of the members here are electrical engineers and would like to see them.
  • Who's Online   0 Members, 0 Anonymous, 382 Guests (See full list)
