November 18, 20186 yr comment_561847 On 11/18/2018 at 6:55 AM, Gav240z said: Use an easy beat to pull out the dings... it uses a tiny weld at the tip and then you use a slide hammer to pull it out. Useful for tricky areas like this with limited access. This sounds like the stud welder I use. I did exactly that but the corners are so thin that the stud welder burns holes in them and if you get a stud welded on, the corner tears out because the metal gets thicker further from the corner. It can be a challenging area to get right. The best tool would be to make some long thin dollies to use from inside the quarter panel Link to comment https://www.classiczcars.com/forums/topic/61045-s30-nos-quarter-panels/?&page=4#findComment-561847 Share on other sites More sharing options...
November 20, 20186 yr comment_561991 On 11/18/2018 at 2:37 PM, Patcon said: This sounds like the stud welder I use. I did exactly that but the corners are so thin that the stud welder burns holes in them and if you get a stud welded on, the corner tears out because the metal gets thicker further from the corner. It can be a challenging area to get right. The best tool would be to make some long thin dollies to use from inside the quarter panel Yes it's kind of like a stud welder, but I'd say far milder. https://www.easybeat.com.au/easybeat-model-3000-car-truck-body-dent-pulling-ma I haven't tried it on the rear 1/4 panels, perhaps they are very thin like you say due to the amount of stretch they would go through via the pressing process? I did have issues using it on the rear hatch once, but that was because I had thinned the metal out a bit already (via angle grinder with flap disc) and we were using a body file to knock down high spots etc.. it did blow a tiny hole. That's when I stopped and decided a small amount of filler may be more appropriate. (gotta learn what not to do sometimes). I agree long thin dollies and perhaps a "slapper" would be another option (if you are not working on the panel off the car). Edited November 20, 20186 yr by Gav240z Link to comment https://www.classiczcars.com/forums/topic/61045-s30-nos-quarter-panels/?&page=4#findComment-561991 Share on other sites More sharing options...
November 20, 20186 yr comment_562012 Looks like a fabulous tool, but not a casual purchase at US$1,500 (plus tax, duty and shipping). Which to buy first: plasma cutter? oxy-acetylene kit? floor lift? induction-heating fastener remover? Link to comment https://www.classiczcars.com/forums/topic/61045-s30-nos-quarter-panels/?&page=4#findComment-562012 Share on other sites More sharing options...
November 20, 20186 yr comment_562014 On 11/17/2018 at 3:27 PM, Patcon said: Not only is it a tough place to hammer back but the metal is incredibly thin at these corners because of the stamping process Some how I ended up with a set of the rear quarter ends that were cut off #777 I believe . The owner was selling all his extras and why someone would have cut off good corners I’ll never know, but I’ve kept them just because it would be hard to fix that area. Though my 3 Z’s are all good in that area Link to comment https://www.classiczcars.com/forums/topic/61045-s30-nos-quarter-panels/?&page=4#findComment-562014 Share on other sites More sharing options...
November 20, 20186 yr comment_562015 On 11/20/2018 at 1:11 PM, madkaw said: Some how I ended up with a set of the rear quarter ends that were cut off #777 I believe . The owner was selling all his extras and why someone would have cut off good corners I’ll never know, but I’ve kept them just because it would be hard to fix that area. Though my 3 Z’s are all good in that area That's a shame. You have to wonder how many sub 1500 cars got parted or scrapped, because "they were too far gone". Today's too far gone is very different than just a few years ago and the standard will continue down. Link to comment https://www.classiczcars.com/forums/topic/61045-s30-nos-quarter-panels/?&page=4#findComment-562015 Share on other sites More sharing options...
November 20, 20186 yr comment_562021 ~ 35% of the 1969 Z's with dates stamps are known to exist today thanks to @Carl Beck!!! Link to comment https://www.classiczcars.com/forums/topic/61045-s30-nos-quarter-panels/?&page=4#findComment-562021 Share on other sites More sharing options...
November 20, 20186 yr comment_562022 On 11/20/2018 at 2:53 PM, 240260280 said: ~ 35% of the 1969 Z's with dates stamps are known to exist today thanks to @Carl Beck!!! Panda eats, shoots and leaves. Link to comment https://www.classiczcars.com/forums/topic/61045-s30-nos-quarter-panels/?&page=4#findComment-562022 Share on other sites More sharing options...
January 1, 20196 yr comment_564994 More on Ebay $4k Price Link to comment https://www.classiczcars.com/forums/topic/61045-s30-nos-quarter-panels/?&page=4#findComment-564994 Share on other sites More sharing options...
January 1, 20196 yr comment_564996 On 1/1/2019 at 8:18 PM, 240260280 said: More on Ebay $4k Price 1987 Dealer suggested retail price was $466.79 ea. Link to comment https://www.classiczcars.com/forums/topic/61045-s30-nos-quarter-panels/?&page=4#findComment-564996 Share on other sites More sharing options...
January 1, 20196 yr comment_564998 If Santa was good: https://www.ebay.com/itm/Datsun-70-78-240Z-260Z-280Z-NOS-OEM-Quarter-Panels-Pair-LH-RH/183612252327?hash=item2ac024a0a7:g:eWkAAOSw1rpcKRNF:rk:6:pf:0 Link to comment https://www.classiczcars.com/forums/topic/61045-s30-nos-quarter-panels/?&page=4#findComment-564998 Share on other sites More sharing options...
January 7, 20205 yr comment_590501 Still available?? Duane.powell13@gmail.com email me in case i don’t respond here please. Link to comment https://www.classiczcars.com/forums/topic/61045-s30-nos-quarter-panels/?&page=4#findComment-590501 Share on other sites More sharing options...
