Shifter Noise (with 'new' bearings) & Brake Drum question '78 280Z
Johnny280
Hi,
i have some (hopefully) easy to fix problems with my 1978 280Z. The car has a pre '81 5 speed in it with a R200 diff. The first problem is a buzzing/mild grinding noise coming from the gearshifter especially in 5th gear, which gets louder the fast you drive. I checked different forums for this problem and the suggested solution was always checking the bushings and plastic cap on the stick. I did that, they are Nissan OEM parts in pristine condition ( is suspect a previous owner swapped them). I am pretty much clueless right now if this is just normal or a serious problem with the gearbox.
The noise dissapears if you hold the stick tight in the right position.
My second problem is a noise coming from the left rear drum brake during right hand cornering. It makes a 'grind grind grind grind grind' noise (faster with higher speeds). Not particular loud or alarming - it is more on the embarassing side. What do you think could be the reason for this?
- worn springs/brake pads
- uneven drum
- broken wheel bearing
- loose backing plate
- Anything else?
Thanks in Advance for your help.
Best Regards
Johnny
- uneven drum
My first thought was a worn bearing or one that wasn't replaced properly.  People have problems installing the rear bearings.
If it only happens when it has a side load that implies that the wheel and everything attached to it might be shifting slightly.  If you take the wheel and drum off you might see some grind marks and/or be bale to feel the wheel flange play.  There is a spec for side play.  It's not much.
It's not uncommon for the backing plates to get bent on the edges when people try to remove the drums.  I had one of those.  You'll see a shiny spot on the edge, where it almost meets the drum.  Actually, where it meets the drum but is not supposed to.
If axle play isn't bad you can just tap or plier (ply?) the ding out and put it all back together.  The rear bearings aren't really super precise.  You can wait to change them.
Edited by Zed Head
Hi,
finally found the time to check both problems.
For the Shift Knob it was really the inlet buzzing (without knob/ with knob without inlet everything is fine). So I will try to glue it back in place with some better glue.
The drum brake noise came from a bent edge on the backplate (thx for the hint zed head). Wheelbearing  play was minimal.  After pulling the drum it was pretty obvious which part was rubbing (ground some nice groove into half of the cooling fins).
Thank you all for your help.
