Posted November 16, 20186 yr comment_561719 Last night the dashboard instrument lights, parking lights and tail lights on my 72 240z shut down when i turned the combo switch on. I noticed that the 15 amp fuse inside the fuse holder provided by Dave Irwin Parking light harness kit went south. Replaced it with another 15 amp and even a 20 amp fuse dashboard lights, tail lights and parking lights came in for 2 seconds and the fuse went out again. I believe the problem resides in the harness upgrade. Last time this happened i removed it from the circuit and connected the stock female and male 6 wire connectors together and all the lights came back. Could there be an issue with the relays provided in the kit? Should i just check the parking light bulbs first and clean for any corrosión before removing the steering colummn cover and making the straight stock connection again? Link to comment https://www.classiczcars.com/forums/topic/61095-parking-light-uprgade-harness-15-amp-fuse-blowing-dashboard-and-tail-lights-gone/ Share on other sites More sharing options...
November 16, 20186 yr comment_561728 Blowing fuses as you describe is a short circuit to ground, somewhere in that circuit. Link to comment https://www.classiczcars.com/forums/topic/61095-parking-light-uprgade-harness-15-amp-fuse-blowing-dashboard-and-tail-lights-gone/#findComment-561728 Share on other sites More sharing options...
November 16, 20186 yr comment_561729 5 hours ago, jalexquijano said: Last night the dashboard instrument lights, parking lights and tail lights on my 72 240z shut down when i turned the combo switch on. I believe the problem resides in the harness upgrade. Last time this happened i removed it from the circuit and connected the stock female and male 6 wire connectors together and all the lights came back. Are you sure that you connected it properly? Didn't nick any wires? Don't put larger fuses in to fix a short circuit problem. Find the short and fix it instead. https://www.datsun-240z-upgrades.net/product-info/ Link to comment https://www.classiczcars.com/forums/topic/61095-parking-light-uprgade-harness-15-amp-fuse-blowing-dashboard-and-tail-lights-gone/#findComment-561729 Share on other sites More sharing options...
November 16, 20186 yr comment_561735 6 hours ago, jalexquijano said: Replaced it with another 15 amp and even a 20 amp fuse dashboard lights Never, ever do this. Unless you want to burn you car to the ground!!! 52 minutes ago, Zed Head said: Are you sure that you connected it properly? Didn't nick any wires? Don't put larger fuses in to fix a short circuit problem. Find the short and fix it instead. https://www.datsun-240z-upgrades.net/product-info/ Find and fix the problem. I could be in the harness, relays. You just have to be systematic Link to comment https://www.classiczcars.com/forums/topic/61095-parking-light-uprgade-harness-15-amp-fuse-blowing-dashboard-and-tail-lights-gone/#findComment-561735 Share on other sites More sharing options...
November 16, 20186 yr comment_561738 I try my best to stay out of these but absolutely DO NOT GO TO A HIGHER FUSE. Link to comment https://www.classiczcars.com/forums/topic/61095-parking-light-uprgade-harness-15-amp-fuse-blowing-dashboard-and-tail-lights-gone/#findComment-561738 Share on other sites More sharing options...
