Posted November 18, 20186 yr comment_561838 Hi! I'm searching for the 240z, 260z Shim doors, upper and lower, in order to adjust the 240Z doors properly. Anyone can get me the pairs? On the picture the arrows show the parts I'm searching. Regards Mário Link to comment https://www.classiczcars.com/forums/topic/61102-datsun-240z-shim-doors/ Share on other sites More sharing options...
November 18, 20186 yr comment_561842 @JLPurcell Didn't you make some shims at some point? Link to comment https://www.classiczcars.com/forums/topic/61102-datsun-240z-shim-doors/#findComment-561842 Share on other sites More sharing options...
November 18, 20186 yr comment_561846 I think it's not very likely that you'll find these Nissan shim plates. Not impossible. Just unlikely. However. they're nothing more than pieces of stamped metal plate. You can easily make your own. For reference, auto body shim plates are typically provided in four thicknesses: 1/64", 1/32", 1/16" and 1/8" (0.4mm, 0.8mm, 1.2mm and 1.6mm). For the door shim plates, a little adjustment at the the front of the door will make for a lot of angular adjustment at the bottom and top of the door, so I'm thinking that a set of 1/64" and 1/32" plates would be the way to go. The thicknesses don't have to be exactly 1/64" or 1/32". Use what you can find conveniently. These shim plates don't need to be pretty and they don't need to be shaped to +/- 0.001" tolerances. Link to comment https://www.classiczcars.com/forums/topic/61102-datsun-240z-shim-doors/#findComment-561846 Share on other sites More sharing options...
November 18, 20186 yr comment_561848 3 minutes ago, Namerow said: I think it's not very likely that you'll find these Nissan shim plates. Not impossible. Just unlikely. However. they're nothing more than pieces of stamped metal plate. You can easily make your own. For reference, auto body shim plates are typically provided in four thicknesses: 1/64", 1/32", 1/16" and 1/8" (0.4mm, 0.8mm, 1.2mm and 1.6mm). For the door shim plates, a little adjustment at the the front of the door will make for a lot of angular adjustment at the bottom and top of the door, so I'm thinking that a set of 1/64" and 1/32" plates would be the way to go. The thicknesses don't have to be exactly 1/64" or 1/32". Use what you can find conveniently. These shim plates don't need to be pretty and they don't need to be shaped to +/- 0.001" tolerances. This is also true. I would want to use something that's not going to rust. You may also find if you get the fender end of the door lined up with the fender, that the rear edge no longer lies flat. In that case I literally twist the door by hand until I can get it to lay flat. That is one of the nice things about thin doors. This work is easier with out the door latch installed. So you can get the door right without any pressure on it Link to comment https://www.classiczcars.com/forums/topic/61102-datsun-240z-shim-doors/#findComment-561848 Share on other sites More sharing options...
November 18, 20186 yr Author comment_561850 21 minutes ago, Patcon said: @JLPurcell Didn't you make some shims at some point? Thanks for answering. I've ones that came with the car, aluminium, but very ugly and don't want to use them. But you gave an excellent idea, I take the ugly ones and make a reproduction. 16 minutes ago, Namerow said: I think it's not very likely that you'll find these Nissan shim plates. Not impossible. Just unlikely. However. they're nothing more than pieces of stamped metal plate. You can easily make your own. For reference, auto body shim plates are typically provided in four thicknesses: 1/64", 1/32", 1/16" and 1/8" (0.4mm, 0.8mm, 1.2mm and 1.6mm). For the door shim plates, a little adjustment at the the front of the door will make for a lot of angular adjustment at the bottom and top of the door, so I'm thinking that a set of 1/64" and 1/32" plates would be the way to go.  The thicknesses don't have to be exactly 1/64" or 1/32".  Use what you can find conveniently. These shim plates don't need to be pretty and they don't need to be shaped to +/- 0.001" tolerances. Thanks for answering! I've them in aluminuim, and I want it original, but you're right, with the correct thickness I can make new ones! I'll try next weekend! You're very helpfull, thanks a lot!!! I'll tell you the result next week! 9 minutes ago, Patcon said: This is also true. I would want to use something that's not going to rust. You may also find if you get the fender end of the door lined up with the fender, that the rear edge no longer lies flat. In that case I literally twist the door by hand until I can get it to lay flat. That is one of the nice things about thin doors. This work is easier with out the door latch installed. So you can get the door right without any pressure on it Thanks for answering! That's true...I used to do it in my 510 and worked, but I noticed this part when started the Z resto, and as a fan of originality I ask for original parts!  Thank you all for answering!!! I'll tell you the result!!! Right now I'll update my post!!!  Regards Mário Link to comment https://www.classiczcars.com/forums/topic/61102-datsun-240z-shim-doors/#findComment-561850 Share on other sites More sharing options...
November 18, 20186 yr comment_561873 BTW don't use aluminum as spacers! The dissimilar metals causes other issues. I agree, your best bet is to make some. I like originality too, but sometimes it's not worth the effort. The older I get, enjoying the car on the road becomes the priority Link to comment https://www.classiczcars.com/forums/topic/61102-datsun-240z-shim-doors/#findComment-561873 Share on other sites More sharing options...
November 18, 20186 yr Author comment_561877 OK Patcon, so I guess I'll use normal metal, the same as the body car? Only with different tchickness. Correct? Regards Mário Link to comment https://www.classiczcars.com/forums/topic/61102-datsun-240z-shim-doors/#findComment-561877 Share on other sites More sharing options...
November 18, 20186 yr comment_561883 2 hours ago, Datsunbat said: OK Patcon, so I guess I'll use normal metal, the same as the body car? Only with different tchickness. Correct? Regards Mário Yes Mario I would use some galvanized steel in the thickness you need then prime or plate them before use Link to comment https://www.classiczcars.com/forums/topic/61102-datsun-240z-shim-doors/#findComment-561883 Share on other sites More sharing options...
November 19, 20186 yr comment_561913 11 hours ago, Patcon said: @JLPurcell Didn't you make some shims at some point? Yes, I had a 100 or so laser cut. I am waiting to make a zinc plating run to Muncie, then they will be ready. Link to comment https://www.classiczcars.com/forums/topic/61102-datsun-240z-shim-doors/#findComment-561913 Share on other sites More sharing options...
November 20, 20186 yr Author comment_561982 21 hours ago, JLPurcell said: Yes, I had a 100 or so laser cut. I am waiting to make a zinc plating run to Muncie, then they will be ready. Awesome!!! If you finish some please make me know! I'll need them to my z.  They are great!!!  Regards Mário Link to comment https://www.classiczcars.com/forums/topic/61102-datsun-240z-shim-doors/#findComment-561982 Share on other sites More sharing options...
November 20, 20186 yr comment_561993 2 hours ago, Datsunbat said: Awesome!!! If you finish some please make me know! I'll need them to my z.  They are great!!!  Regards Mário Plan to possibly take them for plating Wednesday if the company is open. I will let you know when they are plated. JLP Link to comment https://www.classiczcars.com/forums/topic/61102-datsun-240z-shim-doors/#findComment-561993 Share on other sites More sharing options...
April 8, 20196 yr comment_572885 The shims are finally back from plating if anyone is needing some. Link to comment https://www.classiczcars.com/forums/topic/61102-datsun-240z-shim-doors/#findComment-572885 Share on other sites More sharing options...
