November 24, 20186 yr Author comment_562283 On 11/24/2018 at 12:35 PM, jonbill said: In theory... That theory is well known, but presumes you have an engine that is working 100% perfectly and you have a 100% perfect combustion. Edited November 24, 20186 yr by TomoHawk Link to comment https://www.classiczcars.com/forums/topic/61113-legitimacy-of-afr-gauges/?&page=3#findComment-562283 Share on other sites More sharing options...
November 24, 20186 yr comment_562293 On 11/24/2018 at 4:21 PM, Patcon said: But a good first post! Thanks. On 11/24/2018 at 4:50 PM, TomoHawk said: That theory presumes you have an engine that is working 100% perfectly and you have a 100% perfect combustion. Funnily enough, it doesn't - it mainly depends on the chemistry of the fuel and air mixture which hasn't changed for a very long time. I'm sure there are conditions in which the accuracy is compromised significantly, but it's not within the normal degradation of an engine say in the first few 100k miles of it's life. That's why many of the spark ignition cars of the last 20 odd years are still on the road passing their emissions tests using this technology to regulate their fueling. Link to comment https://www.classiczcars.com/forums/topic/61113-legitimacy-of-afr-gauges/?&page=3#findComment-562293 Share on other sites More sharing options...
November 24, 20186 yr Author comment_562294 They also have more than just the one oxygen sensor, in a few places, and modern electronic or digital engine controllers that make up for sensor degradation and other compromises. I see no reason why you can rely on only one oxygen sensor. to get an overall and precise air-fuel mixture determination. Edited November 24, 20186 yr by TomoHawk Link to comment https://www.classiczcars.com/forums/topic/61113-legitimacy-of-afr-gauges/?&page=3#findComment-562294 Share on other sites More sharing options...
November 24, 20186 yr comment_562299 I have a 20 year old mr2 with 3 sensors and 20 year old modern engine management electronics. The first sensor measures the output of cylinders 1 & 4, the second measures the output of cylinders 2 & 3 and the last measures the aggregate after the catalytic converter to judge whether the cat is working or not.I believe this is representative of multisensor setups. Each sensor is trusted to measure its bit independently.Sensors of course do fail.The management system strategy for this is to constantly cycle mixture up and down a bit to check if the sensor reports it. If it doesn't it reports a fault.There's no reason to not believe a single sensor and controller and gauge will report reasonably accurately the average AFR of the combustion chambers it's monitoring. Link to comment https://www.classiczcars.com/forums/topic/61113-legitimacy-of-afr-gauges/?&page=3#findComment-562299 Share on other sites More sharing options...
November 24, 20186 yr Author comment_562303 You are right, about the use of the multi-sensor setup, and how it's all used to get an "average" or overall fuel mix that works reasonably well, and it agrees with my opinion that just the one sensor can't do the whole job. It makes you wonder why so people put their whole confidence in just the one sensor, how there's a whole aftermarket industry that makes a LOT of profit on it. Edited November 24, 20186 yr by TomoHawk Link to comment https://www.classiczcars.com/forums/topic/61113-legitimacy-of-afr-gauges/?&page=3#findComment-562303 Share on other sites More sharing options...
November 24, 20186 yr comment_562306 On 11/24/2018 at 8:29 PM, TomoHawk said: You are right, about the use of the multi-sensor setup, and how it's all used to get an "average" or overall fuel mix that works reasonably well, and it agrees with my opinion that just the one sensor can't do the whole job. It makes you wonder why so people put their whole confidence in just the one sensor, how there's a whole aftermarket industry that makes a LOT of profit on it. Actually the ECU relies on each O2 sensor independently. They are used as much to determine faults and OBD codes as real time fueling. They are also used to cross check each other. Not so much for accuracy but for function. I have found that when it an O2 sensor fails it's dead, not out of spec. So if my wideband O2 fails which it has in the past I get no AFR readings. Link to comment https://www.classiczcars.com/forums/topic/61113-legitimacy-of-afr-gauges/?&page=3#findComment-562306 Share on other sites More sharing options...
November 24, 20186 yr comment_562309 I don’t get this thread. Why are we arguing the science behind a device that is so widely accepted in the industry. It works - use your time for something else IMHO Link to comment https://www.classiczcars.com/forums/topic/61113-legitimacy-of-afr-gauges/?&page=3#findComment-562309 Share on other sites More sharing options...
November 25, 20186 yr comment_562325 On 11/24/2018 at 9:15 PM, madkaw said: I don’t get this thread. Why are we arguing the science behind a device that is so widely accepted in the industry. It works - use your time for something else IMHO When do we get to discuss if the coolant temp sensors are correct or not? AFM? Thermostat? Oh right, we should do something else now.... Edited November 25, 20186 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/61113-legitimacy-of-afr-gauges/?&page=3#findComment-562325 Share on other sites More sharing options...
November 25, 20186 yr Author comment_562331 Because using an oxygen sensor as the sole sensor for the Air-fuel ratio is like measuring tyre pressure using the temperature of the rubber tyre. Link to comment https://www.classiczcars.com/forums/topic/61113-legitimacy-of-afr-gauges/?&page=3#findComment-562331 Share on other sites More sharing options...
November 25, 20186 yr comment_562344 It always bothered me that there isn’t an indicator on the dash to verify I am in 3rd gear and not 5th. Just because I push the shifter further over - how do I really know that I am in 5th and not 3rd? Just because I follow the pattern on that stupid little knob doesn’t mean I have actually changed anything Link to comment https://www.classiczcars.com/forums/topic/61113-legitimacy-of-afr-gauges/?&page=3#findComment-562344 Share on other sites More sharing options...
November 25, 20186 yr comment_562363 On 11/25/2018 at 1:36 AM, madkaw said: Just because I push the shifter further over - how do I really know that I am in 5th and not 3rd? The engineers included a built in audible warning signal that you are in 3rd when you should be in 5th, it sounds like a high pitched turbine combined with breaking metal, very distinctive sound. Link to comment https://www.classiczcars.com/forums/topic/61113-legitimacy-of-afr-gauges/?&page=3#findComment-562363 Share on other sites More sharing options...
November 25, 20186 yr comment_562372 Haha!! From the Zcon thread: On 11/18/2018 at 7:14 PM, Mark Maras said: As the smile starts to spread across my face I shift into 3rd and then 4th gear and put the gas pedal to the floor just to keep up with Bill and Jai. Soon I think, OK, time for 5th gear. Slip it into neutral over to the right and up. Goes in easily, I let out the clutch and immediately realize that it was in 3rd and also realize this is a 4 speed. Edited November 25, 20186 yr by Captain Obvious Link to comment https://www.classiczcars.com/forums/topic/61113-legitimacy-of-afr-gauges/?&page=3#findComment-562372 Share on other sites More sharing options...
