November 27, 20186 yr Author comment_562477 Measuring the coolant temperature is easily done with a temperature sensor like a thermocouple or the LM35 temperature sensor. The Lm35 gives a signal in millivolts proportional to the temperature in degrees C, and you can make an offset circuit for it as well, because 0C related to 0.5Volts, or display it directly using an Arduino program. Is there a practical electronic sensor for intake manifold vacuum. That's also important for having the engine work efficiently. Link to comment https://www.classiczcars.com/forums/topic/61113-legitimacy-of-afr-gauges/?&page=4#findComment-562477 Share on other sites More sharing options...
