12 hours ago, Jughead said:
Makes sense.  Have you ever run into anyone making them?
If this is directed at me, I have not run into anyone making them. If I need them I would make them in the bench vise. The new fabricated ones from the earlier pictures have a weld seam down the sides. So you can fold them all up and then weld down the side. That is what I would do if I needed some. Make a stiff paper template first to pattern from
  • 1 month later...
@Patcon:  See below - Comparing the photo you posted on Nov 22 to another one I've found, .  Yours on the left (A) looks flatter than (B) on the right.  Is that an illusion?Shape Comparison.jpg
Trying to understand the shape before I start fabricating...  Thanks!!  Jughead
