Posted November 24, 20186 yr comment_562287 74 (early) 260Z, It turns over fine and will fire when started is engaged. As soon as the key is released it dies. I heard this may be the ballast resistor. Any suggestions would be appreciated. I need to get this car winterized, but must get it to run again, before that happens. Edited November 24, 20186 yr by Jeff Z misspelled word Link to comment https://www.classiczcars.com/forums/topic/61138-260z-will-fire-with-starter-quits-when-key-is-released/ Share on other sites More sharing options...
November 24, 20186 yr comment_562289 Do you have a multimeter or test light? Link to comment https://www.classiczcars.com/forums/topic/61138-260z-will-fire-with-starter-quits-when-key-is-released/#findComment-562289 Share on other sites More sharing options...
November 24, 20186 yr comment_562290 PM sent Link to comment https://www.classiczcars.com/forums/topic/61138-260z-will-fire-with-starter-quits-when-key-is-released/#findComment-562290 Share on other sites More sharing options...
November 24, 20186 yr comment_562291 I'd look into the ignition switch first. That's a common symptom when they fail. Link to comment https://www.classiczcars.com/forums/topic/61138-260z-will-fire-with-starter-quits-when-key-is-released/#findComment-562291 Share on other sites More sharing options...
November 24, 20186 yr comment_562292 With a multimeter or test light it would be easier to check at the ballast resistor first. Link to comment https://www.classiczcars.com/forums/topic/61138-260z-will-fire-with-starter-quits-when-key-is-released/#findComment-562292 Share on other sites More sharing options...
November 24, 20186 yr Author comment_562295 44 minutes ago, SteveJ said: Do you have a multimeter or test light? Not accessible to me right now, so no. Do you suggest I go get myself one? Edited November 24, 20186 yr by Jeff Z added to message. Link to comment https://www.classiczcars.com/forums/topic/61138-260z-will-fire-with-starter-quits-when-key-is-released/#findComment-562295 Share on other sites More sharing options...
November 24, 20186 yr Author comment_562296 44 minutes ago, Mark Maras said: I'd look into the ignition switch first. That's a common symptom when they fail. Is there a way to test the switch? Link to comment https://www.classiczcars.com/forums/topic/61138-260z-will-fire-with-starter-quits-when-key-is-released/#findComment-562296 Share on other sites More sharing options...
November 24, 20186 yr comment_562301 Get at least a test light. Turn the key to On. Clip the wire on the test light to chassis ground. A common point is one of the bolts on the shock tower. There are three wires on the ballast resistor: white/black, black/blue, and black white. With the key in the On position, you should have voltage at the black/white wire. It has the arrow next to it in the picture Lift the cap on the black/white wire and touch the pointer of the test light to the wire. If the test light lights up, lift the cap on the white/black wire (opposite side of the resistor from the arrow) and touch the test light to that wire. If you didn't have a light on the black/white wire, you have a loose/bad connection or bad ignition switch. You might want to talk to me on the phone about tracking that down. If you have a light on the black/white but not on the white/black, you have a bad ballast resistor. You can move the black/white wire to the same terminal as the white/black, but you shouldn't run it long that way. Link to comment https://www.classiczcars.com/forums/topic/61138-260z-will-fire-with-starter-quits-when-key-is-released/#findComment-562301 Share on other sites More sharing options...
November 24, 20186 yr comment_562308 I had the same problem on my '71 240Z. Car would crank and start fine but as soon as I let the key return to the "ON" position it would die. I replaced the ignition switch thinking that was the most likely source of the problem but it didn't make a difference. I finally tracked it down to a loose/dirty connector on the ballast resistor. I removed the connectors, cleaned them real well, and made sure they were nice and tight when I put them back on and everything works fine now. I believe on the 240Z the ballast resistor is bypassed when in the START (ie. cranking) position but comes into play when the key returns to the ON position. I haven't looked at the 260Z electrical diagram but I would imagine that it might be similar. Link to comment https://www.classiczcars.com/forums/topic/61138-260z-will-fire-with-starter-quits-when-key-is-released/#findComment-562308 Share on other sites More sharing options...
November 24, 20186 yr Author comment_562318 Thanks for the help! I'll let you know when I am able to try out the suggestions. Link to comment https://www.classiczcars.com/forums/topic/61138-260z-will-fire-with-starter-quits-when-key-is-released/#findComment-562318 Share on other sites More sharing options...
December 17, 20186 yr Author comment_563909 I finally got time to get back out there and it turns out one of the posts on the resistor is loose and comes right out. I am assuming this is the problem. Does anyone know where I can find a replacement for this resistor? Or should I do an upgrade? Jeff Link to comment https://www.classiczcars.com/forums/topic/61138-260z-will-fire-with-starter-quits-when-key-is-released/#findComment-563909 Share on other sites More sharing options...
December 17, 20186 yr comment_563926 The 260Z ballast resistor is NLA. You might be able to get away with a 240Z ballast resistor. You would have to move the start wire over to the same terminal as the coil wire. The problem with that is that I don't know why they introduced a small amount of resistance in the starting circuit. If you're worried about that, there is a kludge I could describe to you, but it's not very elegant. Link to comment https://www.classiczcars.com/forums/topic/61138-260z-will-fire-with-starter-quits-when-key-is-released/#findComment-563926 Share on other sites More sharing options...
