Posted May 12, 200321 yr comment_37059 The attached picture is of the grommet on the passenger footwell kickpanel where the cowl drain hose goes through. The drain hose has been removed. It was just loosely glued in place. I'd like to remove this grommet, since as you can see, there is a bit 'O rust on the firewall right beside it that will need to be fixed, and I suspect welding that close wouldn't do it any good. I've poked, prodded, pulled, etc. at it, and it isn't apparent to me how it is attached. It doesn't feel like how the firewall grommets just have a groove that the sheet metal fits in. I've felt around inside the opening, and I actually can't feel a definate edge on the inside, so I'm a little baffled. Any ideas? If I removed the fender, can I see this grommet from the other side? Thanks. Link to comment https://www.classiczcars.com/forums/topic/6116-how-does-this-come-out/ Share on other sites More sharing options...
May 12, 200321 yr Author comment_37060 In case you're interested, the interior of the car is pretty much stripped right now, and looks like the attached photo. Link to comment https://www.classiczcars.com/forums/topic/6116-how-does-this-come-out/#findComment-37060 Share on other sites More sharing options...
May 12, 200321 yr comment_37061 Wow, you have an early 240z becuase I don't see any storage compartments behind the seats. Nice find. Link to comment https://www.classiczcars.com/forums/topic/6116-how-does-this-come-out/#findComment-37061 Share on other sites More sharing options...
May 12, 200321 yr Author comment_37062 Yup, it's #215. I'm looking forward to restoring it as much as I can. It has some pretty serious floor/frame rust issues, but most of that can be fixed with Charlie Osborne's stuff. It's amazing how simple these early cars are. I've probably only spent 20 hours stripping it so far, and in another 20 it'll be nothing but the rolling shell. And that includes taking hundreds of pictures, bagging every bolt and grommet as I take it off, etc. Link to comment https://www.classiczcars.com/forums/topic/6116-how-does-this-come-out/#findComment-37062 Share on other sites More sharing options...
