Posted December 3, 20186 yr comment_562912 Once again getti ng restoration parts ready for zinc plating. Sorting yellow, clear (silver), and black zinc parts for future projects. Every piece media blasted and hand wire brushed. Edited December 3, 20186 yr by JLPurcell Link to comment https://www.classiczcars.com/forums/topic/61189-more-bits-and-pieces-for-plating/ Share on other sites More sharing options...
December 6, 20186 yr comment_563181 Did I hear someone mention plating prep? Link to comment https://www.classiczcars.com/forums/topic/61189-more-bits-and-pieces-for-plating/#findComment-563181 Share on other sites More sharing options...
December 6, 20186 yr comment_563185 Glad I'm not the only one doing this, great to see all the hard work. Which pieces are done in clear and which ones gold cad? Link to comment https://www.classiczcars.com/forums/topic/61189-more-bits-and-pieces-for-plating/#findComment-563185 Share on other sites More sharing options...
December 6, 20186 yr Author comment_563187 On 12/6/2018 at 10:23 PM, jfa.series1 said: Did I hear someone mention plating prep? I see some bits of interest!? Link to comment https://www.classiczcars.com/forums/topic/61189-more-bits-and-pieces-for-plating/#findComment-563187 Share on other sites More sharing options...
December 6, 20186 yr Author comment_563188 On 12/6/2018 at 10:51 PM, SpeedRoo said: Glad I'm not the only one doing this, great to see all the hard work. Which pieces are done in clear and which ones gold cad? Have another batch in the tumbler getting them ready for wire brush. I will sort black, clear and yellow zinc once all parts are ready to go. Link to comment https://www.classiczcars.com/forums/topic/61189-more-bits-and-pieces-for-plating/#findComment-563188 Share on other sites More sharing options...
December 6, 20186 yr comment_563190 What media do you use in the tumbler to clean them. I put mine through the ultrasonic. Anything rusty gets soaked in evaporust and ultrasonically cleaned for an hour or until rust free. I then hit them with the wire brush. Did my Astons and Lotus bits the same way before cad plating. Edited December 6, 20186 yr by SpeedRoo Link to comment https://www.classiczcars.com/forums/topic/61189-more-bits-and-pieces-for-plating/#findComment-563190 Share on other sites More sharing options...
December 6, 20186 yr comment_563192 Great detailed photos. I have some questions to ask: JLPurcell - some pieces are tied together with wires. Is this for grouping them together avoiding sorting later or getting lost? Jfa.series1 - did you do anything with the side light housing socket spring assembly connected with wire? I worked on this piece recently and the spring connection assembly are pre-sealed. Parts with nylon pieces are okay to leave during plating? Link to comment https://www.classiczcars.com/forums/topic/61189-more-bits-and-pieces-for-plating/#findComment-563192 Share on other sites More sharing options...
December 7, 20186 yr comment_563194 On 12/6/2018 at 10:51 PM, SpeedRoo said: Glad I'm not the only one doing this, great to see all the hard work. Which pieces are done in clear and which ones gold cad? Everything in the first two pics will be yellow zinc - not cad. The second two pics will get clear zinc. On 12/6/2018 at 10:56 PM, JLPurcell said: I see some bits of interest!? What... you don't have enough bits already??? On 12/6/2018 at 11:50 PM, 240Ziggy said: Jfa.series1 - did you do anything with the side light housing socket spring assembly connected with wire? I worked on this piece recently and the spring connection assembly are pre-sealed. Parts with nylon pieces are okay to leave during plating? I'm experimenting with rebuilding the sidemarker electrical fittings so no final verdict yet. The nylon items sometimes come back with a white crust that can be scraped clean - there's really no option with parts that are mfg. this way. Link to comment https://www.classiczcars.com/forums/topic/61189-more-bits-and-pieces-for-plating/#findComment-563194 Share on other sites More sharing options...
December 7, 20186 yr comment_563195 I prefer the corrosion resistance of CAD plating so will do all my 240Z pieces that way. Hubs, brakes, suspension, driveshafts will all get it as well as the heap of other bits that seem to pile up once unbolted from the car. Underside of the car is getting full epoxy treatment over the bare metal to keep the tin cancer at bay! Link to comment https://www.classiczcars.com/forums/topic/61189-more-bits-and-pieces-for-plating/#findComment-563195 Share on other sites More sharing options...
December 7, 20186 yr Author comment_563197 On 12/6/2018 at 11:50 PM, 240Ziggy said: Great detailed photos. I have some questions to ask: JLPurcell - some pieces are tied together with wires. Is this for grouping them together avoiding sorting later or getting lost? Jfa.series1 - did you do anything with the side light housing socket spring assembly connected with wire? I worked on this piece recently and the spring connection assembly are pre-sealed. Parts with nylon pieces are okay to leave during plating? Smalls are daisy chained together, with conductive wire, as to not loose any parts during the plating process. Link to comment https://www.classiczcars.com/forums/topic/61189-more-bits-and-pieces-for-plating/#findComment-563197 Share on other sites More sharing options...
December 7, 20186 yr Author comment_563198 On 12/7/2018 at 1:07 AM, SpeedRoo said: I prefer the corrosion resistance of CAD plating so will do all my 240Z pieces that way. Hubs, brakes, suspension, driveshafts will all get it as well as the heap of other bits that seem to pile up once unbolted from the car. Underside of the car is getting full epoxy treatment over the bare metal to keep the tin cancer at bay! I originally wanted to cadmium plate my parts, but it is very expensive, due to the toxic properties. I was told that it is used almost exclusive on aircraft parts today. Definitely more corrosion resistant than the original zinc plating. Link to comment https://www.classiczcars.com/forums/topic/61189-more-bits-and-pieces-for-plating/#findComment-563198 Share on other sites More sharing options...
December 7, 20186 yr Author comment_563199 On 12/7/2018 at 12:55 AM, jfa.series1 said: Everything in the first two pics will be yellow zinc - not cad. The second two pics will get clear zinc. What... you don't have enough bits already??? I'm experimenting with rebuilding the sidemarker electrical fittings so no final verdict yet. The nylon items sometimes come back with a white crust that can be scraped clean - there's really no option with parts that are mfg. this way. Never enough bits! Jim, you already knew that though!!? Link to comment https://www.classiczcars.com/forums/topic/61189-more-bits-and-pieces-for-plating/#findComment-563199 Share on other sites More sharing options...
