If it is a standard, just put it in neutural. If it is an auto you have to remove the driveshaft. Also, the only onter problem I have found is make sure the rockers clear the drive on ramps. This has been a problem for me in the past. The dollie I use now has removeable ramps and U Haul's are good. (And pull nice too)
