December 9, 20186 yr comment_563399 1 hour ago, ryanotown22 said: Ok thanks if the parts I just ordered don’t fit I will just pick that up. Btw my order total price came to 2.18 for the plug and washer from Nissan with local pickup Sent from my iPhone using Classic Zcar Club mobile Good, glad I didn't cost you too much, I was digging through my collection of crush washers and o rings and in a pinch a M8x1.25 and a fuel injector o ring will work temporarily until you can find something more permanent. Link to comment https://www.classiczcars.com/forums/topic/61222-78-280z-fuel-tank-drain-plug/?&page=2#findComment-563399 Share on other sites More sharing options...
December 9, 20186 yr Author comment_563403 Thanks for the help everyone I will report back when I get parts in hand on how they look.Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/61222-78-280z-fuel-tank-drain-plug/?&page=2#findComment-563403 Share on other sites More sharing options...
December 10, 20186 yr Author comment_563463 Well the dealer cancelled my order .. and now status says unavailable Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/61222-78-280z-fuel-tank-drain-plug/?&page=2#findComment-563463 Share on other sites More sharing options...
December 10, 20186 yr comment_563465 32 minutes ago, ryanotown22 said: Well the dealer cancelled my order .. and now status says unavailable Yes, I've had that happen before. Sometimes parts are NLA, but they don't show up in the online searches as such. Link to comment https://www.classiczcars.com/forums/topic/61222-78-280z-fuel-tank-drain-plug/?&page=2#findComment-563465 Share on other sites More sharing options...
December 10, 20186 yr comment_563466 According to Dorman's web-site this one fits. https://www.dormanproducts.com/p-102319-090-039cd.aspx?year=1978&make=Nissan&model=280Z&origin=&parttype=Oil%20Drain%20Plug EDIT: Whoa, Whoa!!! You're talking about the gas tank! I'm sorry. Edited December 10, 20186 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/61222-78-280z-fuel-tank-drain-plug/?&page=2#findComment-563466 Share on other sites More sharing options...
December 10, 20186 yr comment_563467 A tap should cut some new threads pretty easily. Grease up the tap and you won't have to worry too much about shavings, plus gravity will help. Use a magnetic bolt, like for an oil pan, and you'll pick up any strays plus some rust. Link to comment https://www.classiczcars.com/forums/topic/61222-78-280z-fuel-tank-drain-plug/?&page=2#findComment-563467 Share on other sites More sharing options...
December 10, 20186 yr comment_563468 6 minutes ago, siteunseen said: According to Dorman's web-site this one fits. https://www.dormanproducts.com/p-102319-090-039cd.aspx?year=1978&make=Nissan&model=280Z&origin=&parttype=Oil%20Drain%20Plug That's oil. But they might be the same. One funky thread size. Decimal metric? 16,400 microns. 82/127ths of an inch. Edited December 10, 20186 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/61222-78-280z-fuel-tank-drain-plug/?&page=2#findComment-563468 Share on other sites More sharing options...
December 11, 20186 yr Author comment_563564 Ended up at Home Depot with a M8 x 1.25 x 20 flange bolt and M8 copper washer. The flange bolt has a larger head to get good contact with the washer.Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/61222-78-280z-fuel-tank-drain-plug/?&page=2#findComment-563564 Share on other sites More sharing options...
