Posted December 14, 20186 yr comment_563723 All Today's adventure in Parts Hunting starts at the center console of a '77 280Z. Attached thereto is a "Fasten Seat Belt" light fixture, located on the upper vertical panel, just below the radio. It is this fixture that is the subject of the following questions: Hope no.1: Was there, in any model, an instance of a blanking plate for that hole size? If so, does anyone have one they would part with? Hope no.2: Does anyone have a "Seat Belt" fixture housing (bulb holder not required) they would part with? Hopefully, Link to comment https://www.classiczcars.com/forums/topic/61258-details/ Share on other sites More sharing options...
December 14, 20186 yr comment_563725 33 minutes ago, ensys said: All Today's adventure in Parts Hunting starts at the center console of a '77 280Z. Attached thereto is a "Fasten Seat Belt" light fixture, located on the upper vertical panel, just below the radio. It is this fixture that is the subject of the following questions: Hope no.1: Was there, in any model, an instance of a blanking plate for that hole size? If so, does anyone have one they would part with? Hope no.2: Does anyone have a "Seat Belt" fixture housing (bulb holder not required) they would part with? Hopefully, If you are talking about a replacement seat belt fixture I might have one. As far as a blanking plate, I would imagine you would have to make one or replace it with a switch of sorts to power something else. Link to comment https://www.classiczcars.com/forums/topic/61258-details/#findComment-563725 Share on other sites More sharing options...
December 15, 20186 yr Author comment_563816 Well, if one is picky, the issues of texture, edge finish, and attachment make a respectable fabrication unlikely. The blanking plate offers the best opportunity for modification that looks like it belongs without making an irreversible change to originality. Speaking of blanking plates, I find I also need the square one in the middle of the same grouping. Thanks. Link to comment https://www.classiczcars.com/forums/topic/61258-details/#findComment-563816 Share on other sites More sharing options...
December 15, 20186 yr comment_563821 My paltry collection of such items is thus: My expection of worth are of course astronomical. I'm thinking $5 each... hohohoho Edited December 15, 20186 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/61258-details/#findComment-563821 Share on other sites More sharing options...
December 16, 20186 yr Author comment_563858 Mr.zKars: PM sent (I think). Link to comment https://www.classiczcars.com/forums/topic/61258-details/#findComment-563858 Share on other sites More sharing options...
December 17, 20186 yr Author comment_563922 Well folks, I am still looking for blanking plates, both for the console's vertical upper group: - for the 45mm x 29mm "Seat Belts" hole (same as hole on the other end). - for the 23mm x 29mm center hole. Thanks Link to comment https://www.classiczcars.com/forums/topic/61258-details/#findComment-563922 Share on other sites More sharing options...
