Details
ensys
All
Today's adventure in Parts Hunting starts at the center console of a '77 280Z.
Attached thereto is a "Fasten Seat Belt" light fixture, located on the upper vertical panel, just below the radio. It is this fixture that is the subject of the following questions:
Hope no.1:  Was there, in any model, an instance of a blanking plate for that hole size? If so, does anyone have one they would part with?
Hope no.2:  Does anyone have a "Seat Belt" fixture housing (bulb holder not required) they would part with?
Hopefully,
33 minutes ago, ensys said:
All
Hopefully,
If you are talking about a replacement seat belt fixture I might have one.  As far as a blanking plate,  I would imagine you would have to make one or replace it with a switch of sorts to power something  else.
Well, if one is picky, the issues of texture, edge finish, and attachment make a respectable fabrication unlikely.
The blanking plate offers the best opportunity for modification that looks like it belongs without making an irreversible change to originality.
Speaking of blanking plates, I find I also need the square one in the middle of the same grouping.
Thanks.
Well folks, I am still looking for blanking plates, both for the console's vertical upper group:
- for the 45mm x 29mm "Seat Belts" hole (same as hole on the other end).
- for the 23mm x 29mm center hole.
Thanks
