December 29, 20186 yr comment_564764 Thanks. I thought about looking there but assumed that I would have seen it in the past. It's one of my favorite sites. Looks like it mounts in front of the radiator, if that sketchy drawing is showing what I think it is. Unless it's a replacement for the pump-driven fan. The most interesting part might be the "switch thermo". Some of us have spent much time trying to find one that has the right temperature range to run a fan. Seems to be discontinued though. Edited December 29, 20186 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/61285-fan-quiz/?&page=3#findComment-564764 Share on other sites More sharing options...
December 29, 20186 yr comment_564766 The 21595-M0206 switch was used on other models as well, found these specs on the Datsun 1200 site: http://datsun1200.com/modules/mediawiki/index.php?title=Electric_Fan The stock Datsun B310 fan Thermo switch specifications: * Part Number 21595-M0206 * Nominal ON: 85-90C * Spec ON: 83-87° C (181-189 F) * Spec OFF: 78-81° C (172-178 F) * used with 82C thermostat (88C optional) Link to comment https://www.classiczcars.com/forums/topic/61285-fan-quiz/?&page=3#findComment-564766 Share on other sites More sharing options...
December 29, 20186 yr comment_564767 Wouldn't it mount in front of the A/C condenser? My '77 has factory air but no extra fan. Link to comment https://www.classiczcars.com/forums/topic/61285-fan-quiz/?&page=3#findComment-564767 Share on other sites More sharing options...
December 29, 20186 yr comment_564768 I believe I have seen one of those fans in a junk yard. I will need to look again. How does this compare to the 280zx AC? Link to comment https://www.classiczcars.com/forums/topic/61285-fan-quiz/?&page=3#findComment-564768 Share on other sites More sharing options...
December 29, 20186 yr comment_564771 19 hours ago, zspert said: Actually it's spelled Banzai ? Hey welcome back to the site!! Glad to see you participating again. -- Mike Link to comment https://www.classiczcars.com/forums/topic/61285-fan-quiz/?&page=3#findComment-564771 Share on other sites More sharing options...
December 29, 20186 yr comment_564786 Thank you Mike. Link to comment https://www.classiczcars.com/forums/topic/61285-fan-quiz/?&page=3#findComment-564786 Share on other sites More sharing options...
December 30, 20186 yr Author comment_564815 Then there is this: I have found no reference to the piece of wiring harness that would connect to the main (by the glove box), and extend thru the engine room to the fan (which is shown mounted to the fan sheetmetal bulkhead in front of the radiator). In addition, as so ably noted by Mr.O, one wire is hot, and the other is switched, implying that there is a relay (and its harness) involved in the fan installation. Of course, the likely scenario would have the in (water) line switch (shown in the diagram) connected to this relay for automatic temp-sensitive operation; that would require yet another piece of harness... Interesting mystery, eh? Link to comment https://www.classiczcars.com/forums/topic/61285-fan-quiz/?&page=3#findComment-564815 Share on other sites More sharing options...
January 9, 20196 yr comment_565567 On 12/23/2018 at 1:54 AM, ensys said: - And now, the $64 question: exactly where are the two connectors for the fan to be found on the stock harness? On 12/23/2018 at 1:15 PM, Captain Obvious said: I reattached a couple of my previous pics here... The two connections for that sub-harness are under the dash above the passengers right knee. Tucked up to the right of the glove box: @ensys Seeing how @Captain Obvious gave the correct answer, and @CanTechZ followed up with the snip of the microfiche, do they have to split the $64???? On 12/28/2018 at 6:26 PM, Zed Head said: No offense intended zspert. I thought it was a humorous way to acknowledge that you've been a member for 15 years, and that your last two posts (50% of your content at the time of my post) were in 2013. Then you posted two within minutes of each other. In person, it might have been "dude, where have you been?!". Which some people probably would think is rude, if they were present. Humor can be a complex subject. Welcome (back) to the forum. You can probably add a lot, with your experience, if you want to, and can stand an occasional joke. Not all of us have the microfiche. So, if anyone wants to share, feel free. @Zed Head Sorry, I didn't 'see' or read the humor then nor now. I guess I'm slow. As you state, Humor can be a complex subject. I know my humor can be dry, stretched, or even referring back to something 10 years ago. I'm pretty sure @zspert will add to the forum with his experience, no probably inferred. I followed the "Merry Christmas" thread, that was funny as it continued on. Again, I'm sorry I didn't see the humor in your original response. FWIW, the microfiche is available in the download section for a very small donation to support the CZCC club... Wayne Wayne Link to comment https://www.classiczcars.com/forums/topic/61285-fan-quiz/?&page=3#findComment-565567 Share on other sites More sharing options...
January 9, 20196 yr comment_565568 36 minutes ago, wal280z said: Sorry, I didn't 'see' or read the humor then nor now. I guess I'm slow. As you state, Humor can be a complex subject. I know my humor can be dry, stretched, or even referring back to something 10 years ago. I'm pretty sure will add to the forum with his experience, no probably inferred. I followed the "Merry Christmas" thread, that was funny as it continued on. Again, I'm sorry I didn't see the humor in your original response. You @'ed me just to say your sorry, and point out specifically, twice, that you didn't think it was funny? Thanks, that was considerate. p.s. that's mild sarcasm, often 'seen' as funny. @wal280z I think that zspert was fine with it. Carry on! Edited January 9, 20196 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/61285-fan-quiz/?&page=3#findComment-565568 Share on other sites More sharing options...
January 9, 20196 yr comment_565569 Burying the lede, topic mode... Link to comment https://www.classiczcars.com/forums/topic/61285-fan-quiz/?&page=3#findComment-565569 Share on other sites More sharing options...
