Posted December 24, 20186 yr comment_564367 I purchased a used fuel rail with injectors attached to it. The seller didnt say if they were off of a turbo model or not. Is there a product number I can reference? Or any way to figure out if they are NA injectors? I pulled them off to have them cleaned. And I have a Pallnet rail coming in here soon. Thank you Link to comment https://www.classiczcars.com/forums/topic/61291-280zx-non-turbo-injectors/ Share on other sites More sharing options...
December 24, 20186 yr comment_564370 Post a picture of one. Try to get the part number also. Nissan used a common part number but different colors for their injectors. If they're aftermarket the part number might tell something. If they're Nissan the color will. Cleaning injectors isn't worth a lot but the flow testing will be valuable. Don't do cleaning without flow testing. Link to comment https://www.classiczcars.com/forums/topic/61291-280zx-non-turbo-injectors/#findComment-564370 Share on other sites More sharing options...
December 24, 20186 yr Author comment_564373 29 minutes ago, Zed Head said: Post a picture of one. Try to get the part number also. Nissan used a common part number but different colors for their injectors. If they're aftermarket the part number might tell something. If they're Nissan the color will. Cleaning injectors isn't worth a lot but the flow testing will be valuable. Don't do cleaning without flow testing. I'll get a picture for you real soon. They are green tops I do know that. The place I'm taking them too does a clean and flow test all in the same sorta package. I took my injectors off my 02 Rsx Type-s and they did a great job. They are off an 81 model 280zx Link to comment https://www.classiczcars.com/forums/topic/61291-280zx-non-turbo-injectors/#findComment-564373 Share on other sites More sharing options...
December 24, 20186 yr comment_564374 Green is the color of Nissan NA units, but it's also a common aftermarket color. They're probably Nissan NA injectors. We still like to look at pictures though. Link to comment https://www.classiczcars.com/forums/topic/61291-280zx-non-turbo-injectors/#findComment-564374 Share on other sites More sharing options...
December 26, 20186 yr Author comment_564532 On 12/23/2018 at 10:11 PM, Zed Head said: Green is the color of Nissan NA units, but it's also a common aftermarket color. They're probably Nissan NA injectors. We still like to look at pictures though. Link to comment https://www.classiczcars.com/forums/topic/61291-280zx-non-turbo-injectors/#findComment-564532 Share on other sites More sharing options...
December 27, 20186 yr comment_564563 Those are common Bosch injectors for the NA ZX engines. It's not clear if Nissan installed them or they are a common dealer replacement but many ZX's have them. I picked up a set myself from a wrecking yard car. Here's a recent re-energized thread about them. The last post is informative. The picture below shows the Nissan version of what you have. Put some new fuel injector hose on after getting them cleaned and they should work fine, unless they've been exposed to moisture. Apparently the innards rust easily. The hose replacement procedure is in the Engine Fuel chapter of the FSM. Edited December 27, 20186 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/61291-280zx-non-turbo-injectors/#findComment-564563 Share on other sites More sharing options...
December 27, 20186 yr Author comment_564580 Thank you so much! They were attached to a rail I bought and it was all wrapped up in plastic wrap so I hope the inside is all good. I'll go look through that thread! Link to comment https://www.classiczcars.com/forums/topic/61291-280zx-non-turbo-injectors/#findComment-564580 Share on other sites More sharing options...
