December 28, 20186 yr comment_564630 I had heard that the sweep style of the later AFM's was different than the earlier ones... Something like the ZX's used a logarithmic sweep for the voltage while the earlier Z's used a linear output? I have no input as to the validity of that, but I think I read it on the internets. Link to comment https://www.classiczcars.com/forums/topic/61308-afm-switch/?&page=2#findComment-564630 Share on other sites More sharing options...
December 28, 20186 yr comment_564636 Seems reasonable. The ZX's used a different ECU also. I wonder if the circuit boards inside might be the same. Something we can compare without too much trouble. Probably have numbers. Link to comment https://www.classiczcars.com/forums/topic/61308-afm-switch/?&page=2#findComment-564636 Share on other sites More sharing options...
December 28, 20186 yr comment_564639 Here's a start. An A31 060 001 from a 1975 280Z, I think. Kind of looks like a Bosch part number on the board, but it says OHMIC. 1 288 310 011 with a big 7444 beside it. Link to comment https://www.classiczcars.com/forums/topic/61308-afm-switch/?&page=2#findComment-564639 Share on other sites More sharing options...
December 28, 20186 yr comment_564670 13 hours ago, Zed Head said: board, says OHMIC. 1 288 310 011 with a big 7444 beside it. I suspect OHMIC is a company that Bosch sub-contracted out to for construction of the board. I bet that Bosch did not silk screened their own boards. And the 7444 is probably a date code for 44th week of 74 (making it a prime candidate for the 75 model year). Link to comment https://www.classiczcars.com/forums/topic/61308-afm-switch/?&page=2#findComment-564670 Share on other sites More sharing options...
December 28, 20186 yr comment_564679 It's a bosch unit. That is a Bosch symbol next to the "+" symbol. I think OHMIC desrcibes the type of contact used to measure resistence and therefore vane position. "Generally the term "ohmic contact" implicitly refers to an ohmic contact of a metal to a semiconductor, where achieving ohmic behaviour is possible but requires careful technique" https://en.m.wikipedia.org/wiki/Ohmic_contact Link to comment https://www.classiczcars.com/forums/topic/61308-afm-switch/?&page=2#findComment-564679 Share on other sites More sharing options...
December 28, 20186 yr comment_564685 The AFM cover was the typical green Nissan label. If later AFM's use the same board the odds are good, I think, that the "tuning" is the same. Anybody got a 1978 handy? I think I sent mine to @rcb280z I have an MSA AFM on my car now. MSA says that Fuel Injection Corp. uses a thicker material on the conductive pattern to make it more durable. Link to comment https://www.classiczcars.com/forums/topic/61308-afm-switch/?&page=2#findComment-564685 Share on other sites More sharing options...
December 28, 20186 yr comment_564688 Zed Head, the one I got from you has the 7 pins and fuel pump cut off so I assume its a 77. Link to comment https://www.classiczcars.com/forums/topic/61308-afm-switch/?&page=2#findComment-564688 Share on other sites More sharing options...
December 28, 20186 yr comment_564689 Chiefmd, I think "if" you need to do anything to the refurbished unit, after installing on your 77, it will just be an adjustment on the "idle air screw" at the bottom of the AFM. This is assuming it hasn't been opened and molested. Link to comment https://www.classiczcars.com/forums/topic/61308-afm-switch/?&page=2#findComment-564689 Share on other sites More sharing options...
December 28, 20186 yr comment_564693 1 hour ago, rcb280z said: Zed Head, the one I got from you has the 7 pins and fuel pump cut off so I assume its a 77. It's a 78, pretty sure, I got it from a 1978 parts car that seemed all original. The fuel pump pins are "useless" as I showed above, post #8, with the Nissan wiring diagram. Nissan probably had old AFM's in stock when they made the model switch. If you can get the part number from the board that would be cool. No picture necessary, although pictures do add something. Link to comment https://www.classiczcars.com/forums/topic/61308-afm-switch/?&page=2#findComment-564693 Share on other sites More sharing options...
December 29, 20186 yr comment_564714 It has the fuel pump cut off inside. It worked on my 77 when I tested it otherwise I would not have used it. Here's a pic of the board. Edited December 29, 20186 yr by rcb280z Link to comment https://www.classiczcars.com/forums/topic/61308-afm-switch/?&page=2#findComment-564714 Share on other sites More sharing options...
December 29, 20186 yr comment_564718 Thanks, looks like it has the Nissan A31 number, along with an extra number. No simple Bosch number comparisons. Dang. Link to comment https://www.classiczcars.com/forums/topic/61308-afm-switch/?&page=2#findComment-564718 Share on other sites More sharing options...
December 29, 20186 yr comment_564724 Here's a pic of the AFM in my 77. I haven't owned the car since new so I can't guarantee that it's original, but I believe it is: Seems the later AFM's used the green protective screen printed coating over the laser trimmed resistors. Link to comment https://www.classiczcars.com/forums/topic/61308-afm-switch/?&page=2#findComment-564724 Share on other sites More sharing options...
