[2019] What Did You Do To/with Your Z Today?
zed2
Modified my Dave Irwin headlight relay harness by replacing the 240Z non-weatherproof connectors with Delphi WeatherPack connectors. I did not want to hack up my original 280Z headlight pigtails with their impossible-to-find Yazaki YPC connectors.
Finally got around to installing the harmonic damper I received for my 280 from Jeff "JSM" about 6 months ago and all is good. There was some question about its stability because of the small crack in the rubber portion of the pulley. I just Trimmed it down flush with the pulley and it looks as if the crack was never there. Plus I had a shop check it out and they said it is good.
New oil and filter then went for a 240 ride for two hours!  I've only put 378 miles on it since 12/16/'16, the last oil change.  Life...go figure.
280 sits, uninsured with no battery but covered inside my garage.
You live in Alabama...you should enjoy them more.
