April 14, 20196 yr comment_573306 A little cake, a little carburetor , what else can a man ask for? Hope it was a good one @Zup! Link to comment https://www.classiczcars.com/forums/topic/61322-2019-what-did-you-do-towith-your-z-today/?&page=6#findComment-573306 Share on other sites More sharing options...
April 14, 20196 yr comment_573307 58 minutes ago, Patcon said: Happy Birthday @Zup Ditto that from me too Charles. He gave me an early present when he sent me a door for my sculpture.......a super member! Link to comment https://www.classiczcars.com/forums/topic/61322-2019-what-did-you-do-towith-your-z-today/?&page=6#findComment-573307 Share on other sites More sharing options...
April 14, 20196 yr comment_573308 Thanks Jim2! And Charles, and Gary and Guy.... Had the best Birthday ever! Such good friends came to celebrate here at home and many thanks to you all for your wishes and influence in my life----you really are so special to me. Kagy (the wife) gave me a button to wear on my 70th that said---  In dog years...I'm dead! Well... closer for sure... but not yet... thankfully! You guys are the best!!! Link to comment https://www.classiczcars.com/forums/topic/61322-2019-what-did-you-do-towith-your-z-today/?&page=6#findComment-573308 Share on other sites More sharing options...
April 14, 20196 yr comment_573310 Jim's flattering cake and gift! Link to comment https://www.classiczcars.com/forums/topic/61322-2019-what-did-you-do-towith-your-z-today/?&page=6#findComment-573310 Share on other sites More sharing options...
April 14, 20196 yr comment_573322 Changed my exhaust system again. Abandoned the Zstory stainless headers and went back to the stock exhaust manifold (ceramic coated) and installed a new dowm tube a two into one 2.5 inch pipe. Added a custom bend pipe to meet up to the Zstory resonator. Connected everything with stainless V clamps. I’ll run it as is for a while and then remove the new pipe and have it ceramic coated. Next up is the transmission  whine I get in 1st 2nd and 3rd. Probably a propessional rebuild. Link to comment https://www.classiczcars.com/forums/topic/61322-2019-what-did-you-do-towith-your-z-today/?&page=6#findComment-573322 Share on other sites More sharing options...
April 14, 20196 yr comment_573325 26 minutes ago, 7tooZ said: Changed my exhaust system again. Abandoned the Zstory stainless headers and went back to the stock exhaust manifold (ceramic coated) and installed a new dowm tube a two into one 2.5 inch pipe. Added a custom bend pipe to meet up to the Zstory resonator. Connected everything with stainless V clamps. I’ll run it as is for a while and then remove the new pipe and have it ceramic coated. Next up is the transmission  whine I get in 1st 2nd and 3rd. Probably a propessional rebuild. Why did you go back to the stock manifold? Link to comment https://www.classiczcars.com/forums/topic/61322-2019-what-did-you-do-towith-your-z-today/?&page=6#findComment-573325 Share on other sites More sharing options...
April 15, 20196 yr comment_573344 My install purchase a full system which went together well with a few exception. On cars with SUs there is not enough space to used the stock heat shield so custom spring brackets were required. Additionally the exhaust tube for number six cylinder protruded to approximately 3/4 inch below the soft rubber tube on the bottom of the rear SU.  I was uncomfortable with a 450+  degrees that close and no room for a heat shield. The next header solved the close contact to the SU but made contact with the torsion rod bracket and would require custom fabrication. Up until now I have used a ceramic coated stock manifold and down pipe with 2.25 exhaust a glass pack resonator an a magnaflow muffler. So I decided to experiment with Sean’s stainless system and the changes I mentioned above. So far so good. Nice sound under throttle but a little loud at WOT. Nice low tone at 70 mph  at 2500-2700 rpm. I like the fact that the stainless system uses V clamps on the resonator making it east to remove the system for other work. Tucks up tight except where the pipe is next to the diff. Looks great from the back. Edited April 15, 20196 yr by 7tooZ Link to comment https://www.classiczcars.com/forums/topic/61322-2019-what-did-you-do-towith-your-z-today/?&page=6#findComment-573344 Share on other sites More sharing options...
April 15, 20196 yr comment_573350 12 hours ago, Patcon said: Why did you go back to the stock manifold? I use the stock manifold on my cars. Never really liked the hollow sound of headers and have heard (but can’t verify) that headers don’t add that much h.p......stock exhaust manifolds are fairly efficient.  If I were building a true race car, I would go headers......on the street, stock manifold works for me.  IMO Link to comment https://www.classiczcars.com/forums/topic/61322-2019-what-did-you-do-towith-your-z-today/?&page=6#findComment-573350 Share on other sites More sharing options...
April 15, 20196 yr comment_573384 10 hours ago, Diseazd said: I use the stock manifold on my cars. Never really liked the hollow sound of headers and have heard (but can’t verify) that headers don’t add that much h.p......stock exhaust manifolds are fairly efficient.  If I were building a true race car, I would go headers......on the street, stock manifold works for me.  IMO I guess most of my question was just based on the impression that Sean(?) makes some very nice exhaust parts. I don't necessarily consider it a move backwards, but was looking for the impetus Link to comment https://www.classiczcars.com/forums/topic/61322-2019-what-did-you-do-towith-your-z-today/?&page=6#findComment-573384 Share on other sites More sharing options...
April 16, 20196 yr comment_573399 Gave the Z its spring bath Pulled the latest barn find out to see the light of day Picture 2 - 6 weeks ago Link to comment https://www.classiczcars.com/forums/topic/61322-2019-what-did-you-do-towith-your-z-today/?&page=6#findComment-573399 Share on other sites More sharing options...
April 20, 20196 yr comment_573745 Had a noise in my ZX tranny in the 73, so I decided to install the one that Eiji rebuilt for me. I’m also taking out the Exedy Stage I performance clutch (too strong for my use) and installing an Exedy stock 240 mm clutch. If anyone wants the clutch and disc (240 mm) for $200.00 plus shipping, it’s theirs (I paid $475.00 and only has 1500 easy miles). Wow, a transmission jack makes it so much easier.....of course the lift does too ? Edited April 20, 20196 yr by Diseazd Link to comment https://www.classiczcars.com/forums/topic/61322-2019-what-did-you-do-towith-your-z-today/?&page=6#findComment-573745 Share on other sites More sharing options...
April 20, 20196 yr comment_573750 Hey, what kind of 4 post lift are you using. Starting to do my research and looking at the bendpak HD9 or a Eagle. Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/61322-2019-what-did-you-do-towith-your-z-today/?&page=6#findComment-573750 Share on other sites More sharing options...
