vintage dashes 280z
Dave WM
Got a call from Fedex, should be delivered tomorrow, anybody interested in seeing an unboxing video?
I have a spare dash, I could strip the old bunged up dash pad off, just to make sure I know how this one should fit (a dry run if you will). That way I could do the test fitting in the comfort of A/C indoors.
Edited by Dave WM
Oh gosh, it’s been about 15 months since I pulled it!  At my age, remembering yesterday takes a bit of head scratching!
If I recall correctly, the FSM procedure was pretty good.  Steering wheel, combo switches, seats, console come out before the dash.  Disconnecting the speedometer cable was awkward.  Disconnecting the flashers and the connections under the dash around the steering column were a bit easier.  That’s all I can think of at the moment.  Good luck, Dave!
  • Who's Online   1 Member, 1 Anonymous, 743 Guests (See full list)
