Im having a bit of trouble figuring out how to replace a figure 8 seal that is supposedly under the jet block assembly? This is for a Solex 44phh carburetor i believe is type 5. Apparently the figure 8 seal isn't listed on the main blow up diagram.
Thanks for reply,
do you know which screws it is? Is it only one? Is it right underneath the area where the jet assembly block is? Do I need to remove the pump diaphragm to gain access? I think I remember seeing it but not sure
Edited by fairladyz432
If you remove the pump housing, one larger phillips (JIS) screw hold the jet holding block assembly in.  It's always a tough screw for me.  Probably my least favorite on the carbs.  When you install it again, put a tiny bit of grease on the threads.  Cheers
Recently Browsing 0
Who's Online (See full list)
