Posted January 11, 20196 yr comment_565720 5 part series (short) since youtube does not have a video editor anymore. Link to comment https://www.classiczcars.com/forums/topic/61386-broken-manifold-bolt-repair-using-new-tool/ Share on other sites More sharing options...
January 11, 20196 yr comment_565722 Dave , only part 1 of 5 are shown. Link to comment https://www.classiczcars.com/forums/topic/61386-broken-manifold-bolt-repair-using-new-tool/#findComment-565722 Share on other sites More sharing options...
January 11, 20196 yr Author comment_565723 I did not want to clutter up the site, just click on my channel they are all there. Link to comment https://www.classiczcars.com/forums/topic/61386-broken-manifold-bolt-repair-using-new-tool/#findComment-565723 Share on other sites More sharing options...
January 11, 20196 yr Author comment_565724 https://www.youtube.com/channel/UCxMsHgfGwCVtyRrqXVtll-g?view_as=public Link to comment https://www.classiczcars.com/forums/topic/61386-broken-manifold-bolt-repair-using-new-tool/#findComment-565724 Share on other sites More sharing options...
January 11, 20196 yr comment_565725 If you need a video editor, Cyberlink makes an older version of their Powerdirector software available as a free download. https://www.cyberlink.com/products/powerdirector-video-editing-software/features_en_US.html I found it fairly easy to use. One of the main limitations is that you can't do 4K video in the free version. Link to comment https://www.classiczcars.com/forums/topic/61386-broken-manifold-bolt-repair-using-new-tool/#findComment-565725 Share on other sites More sharing options...
January 11, 20196 yr comment_565726 Thanks for the link Link to comment https://www.classiczcars.com/forums/topic/61386-broken-manifold-bolt-repair-using-new-tool/#findComment-565726 Share on other sites More sharing options...
January 11, 20196 yr Author comment_565728 the OTC tool is very simple, but precision made and works very well. The only thing is having the engine on the stand makes everything a lot easier as far as setup and drilling. I suppose you could do it with the engine in the car, just a bit harder to get good access for the placement of the drill. a 90 angle driver would prob make life easier if that was the case. part 4 note: In this video you can see the alignment tool installed incorrectly. I reversed it so the bushing that is bolted to the head could be over the hole to be tapped. The reason being the bushing has a much larger hole (8mm) that let me use it to make sure the tap was going in straight. Its not designed for this but it did help with the start of the tap process. Edited January 11, 20196 yr by Dave WM Link to comment https://www.classiczcars.com/forums/topic/61386-broken-manifold-bolt-repair-using-new-tool/#findComment-565728 Share on other sites More sharing options...
