January 18, 20196 yr comment_566178 The E-30 heads are 37cc Chambers compared to 39-41cc on the E-31 or E-88. I run 37cc chambers on my L24 , but it’s a e88 that has been shaved a bit ? I also have significant bore notching which lowers compression . That coupled with a 490/290 cam I have no issues with detonation with 93 octane. The L20 ran dished pistons with those tiny chambers Link to comment https://www.classiczcars.com/forums/topic/61417-interesting-early-z-on-bat/?&page=2#findComment-566178 Share on other sites More sharing options...
January 18, 20196 yr comment_566182 I re-discovered an orphan E-30 head in my pile last month while looking for other things. It should find a new home... hint hint.... Link to comment https://www.classiczcars.com/forums/topic/61417-interesting-early-z-on-bat/?&page=2#findComment-566182 Share on other sites More sharing options...
January 19, 20196 yr comment_566250 On 1/18/2019 at 10:47 AM, zKars said: I re-discovered an orphan E-30 head in my pile last month while looking for other things. It should find a new home... hint hint.... It would be a great head for a L24 . Not sure how big the ports can go - I know they are smaller . Great chamber design and square port exhaust . Link to comment https://www.classiczcars.com/forums/topic/61417-interesting-early-z-on-bat/?&page=2#findComment-566250 Share on other sites More sharing options...
January 19, 20196 yr comment_566252 19 minutes ago, madkaw said: It would be a great head for a L24 . Not sure how big the ports can go - I know they are smaller . Great chamber design and square port exhaust . The ports look pretty little. Assuming the castings are similar to later heads there may be plenty to work with to make them bigger, but no guarantees. Link to comment https://www.classiczcars.com/forums/topic/61417-interesting-early-z-on-bat/?&page=2#findComment-566252 Share on other sites More sharing options...
January 19, 20196 yr comment_566264 On 1/18/2019 at 12:32 PM, madkaw said: The L20 ran dished pistons with those tiny chambers It's a mistake to talk about the 'L20' six as though it is just one thing. From 1964/5's 'L20' through L20(A), L20AT, L20AE, L20E, L20T and on into the mid 1980s there were many, many variants. 130ps 9.5:1 L20(A) as fitted to the first Fairlady Zs in 1969 and 1970 certainly had flat top - not dished - pistons. Link to comment https://www.classiczcars.com/forums/topic/61417-interesting-early-z-on-bat/?&page=2#findComment-566264 Share on other sites More sharing options...
January 20, 20196 yr comment_566274 My JDM - 1972 Fairlady Z: L20A engine, E30 head, 38mm carbs HJG38 Link to comment https://www.classiczcars.com/forums/topic/61417-interesting-early-z-on-bat/?&page=2#findComment-566274 Share on other sites More sharing options...
