i have rebuilt 3.1 stroker motor with brand new 45 webers. My question is what jets should i use to get the car to run good enough to take it to someone who can tune the carbs. the carbs are synced and the car runs and idles great. the car is driveable but between 1-3k it is sluggish im wondering if maybe the jets need to be changed.  The 45 webers have stock jets in them.
3.1L
f54 flat top pistons 89mm
n42 head with big valves and race port
540/290 cam
zstory full exhaust system
using a stock distributor w petronix
ATI damper
im located in ventura county CA
any help would be great
thanks alot
What size are the chokes?  34-35mm would be great for street.
How many progression holes?
This works for  2.8l, you may need more fuel at wot.
65F9 idle jets
Set fuel level ~28mm
For mains a 165 jet with 160 air may get you going. E-tube (other than F2) will not make a big difference.
