Have you heard of Auveco? They supply lots of little plastic items like this - and although I have downloaded their catalog, I haven't sat down to actually LOOK at it...
https://www.auveco.com/
When I looked at car parts manual for the part breakdown it just listed the whole bucket as “ASSY-BODY HEAD LAMP” with no separate call out for the plastic nuts.
They apply to all S30's.
They will work, although the plastic housing is somewhat different---your photo of the screw housing ( I assume from your 10/70 car) does not fully enclose the threaded portion of the adjusting screw---which I find interesting as my 7/70 had the fully enclosed type.
Mine had transparent caps over the ends so they were enclosed too. The material had hardened over time and I had to break/cut them off. The shape of the end of the nut is barbed so a cap or improvised tubing will work.
Edited by SurferD
Next I need to find the rubber grommets for where the wires go through the back. Zcardepot has them for $36.50 but that seems hugely expensive.
https://zcardepot.com/products/headlight-bucket-wire-seal-rubber-pair-240z-260z-280z
Edited by SurferD
  • 3 weeks later...
So I got the set from the bay seller and they are very good. they are the correct dimensions and are made of ABS. My only gripe is that the screws supplied are very tight and I think the ID of the parts is a little small. I used some Elmer's Dry lube on them and they are a little easier. The new screws are smalIer diameter than stock. I definitely recommend these for restoring light buckets. Another interesting change that I found and never read about before from series one to later versions of the lights is the recessed mounting locations of these nuts. On my original ones there's a stamped area with serrations so they don't spin. On later buckets I have, it's a more pronounced full rectangular stamping. Also on the early buckets there's no holes for the locating nibs on the new gaskets. I drilled 4mm holes so the gaskets fit. Another "why would they do that" find.
Edited by SurferD
