February 12, 20196 yr comment_568091 9 hours ago, ConVerTT said: Woohoo! Driver side welded in. Straight and true.... So it is spot welded in for now. I will finish the seam welding and cleanup on the rotisserie once it is off the jig. Welding out of position SUCKS!!! Time to start in on the bad side .... Nice firewall Rail cut out easily enough though .... ‘ Check out all the rust that came out of this rail .... +1 for the jig. Glad I didn’t try to put that directly on to the rotisserie .... The really scary part is that use to be metal and the frame is directly weaker for that lack of metal. Plenty of Z's out there with similar unseen weakness. There are a couple of areas in those pictures that are especially hard to repair. The compound curves in the foot well and the compound curve area under the battery tray. Will be interesting to see how you approach those. You obviously have good metal skills. Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=4#findComment-568091 Share on other sites More sharing options...
February 12, 20196 yr comment_568103 Looking forward to seeing how you tackle that little mess, D/S looks fantastic! Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=4#findComment-568103 Share on other sites More sharing options...
February 12, 20196 yr comment_568109 You might consider buying the ready-made battery-area repair panel that Z-Car Depot offers... https://zcardepot.com/collections/sheet-metal/products/battery-tray-area-sheet-metal-patch-240z-260z-280z On sale right now at US$100, it's attractively priced... although you'll probably be out of pocket by Cdn $300 by the time it arrives in Ft. Saskatchewan. If nothing else, though, the photos on their website might give you some thoughts on how to go about making your own. And, before I forget: I've read in the past that the contours of the inner fender sheet metal in the battery tray area can be nicely matched by carving a particular section out of a front fender (if you happen to have a spare lying around that you don't need). Maybe someone else can comment with more detail. Edited February 12, 20196 yr by Namerow additional comment added Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=4#findComment-568109 Share on other sites More sharing options...
February 12, 20196 yr comment_568115 40 minutes ago, Namerow said: You might consider buying the ready-made battery-area repair panel that Z-Car Depot offers... https://zcardepot.com/collections/sheet-metal/products/battery-tray-area-sheet-metal-patch-240z-260z-280z On sale right now at US$100, it's attractively priced... although you'll probably be out of pocket by Cdn $300 by the time it arrives in Ft. Saskatchewan. Ooooooooo! It's coming to my location?! @ConVerTT is located 3 hours south of me. Where the sunshine is.... Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=4#findComment-568115 Share on other sites More sharing options...
February 12, 20196 yr Author comment_568124 5 hours ago, Patcon said: The really scary part is that use to be metal and the frame is directly weaker for that lack of metal. Plenty of Z's out there with similar unseen weakness. There are a couple of areas in those pictures that are especially hard to repair. The compound curves in the foot well and the compound curve area under the battery tray. Will be interesting to see how you approach those. You obviously have good metal skills. Thanks Patcon. Yeah I knew the rail was bad, but holy crap Batman - I was surprised HOW bad ? Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=4#findComment-568124 Share on other sites More sharing options...
February 12, 20196 yr Author comment_568126 3 hours ago, grannyknot said: Looking forward to seeing how you tackle that little mess, D/S looks fantastic! Thanks grannyknot. It will certainly be the hardest piece yet! Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=4#findComment-568126 Share on other sites More sharing options...
February 12, 20196 yr Author comment_568127 2 hours ago, Namerow said: You might consider buying the ready-made battery-area repair panel that Z-Car Depot offers... https://zcardepot.com/collections/sheet-metal/products/battery-tray-area-sheet-metal-patch-240z-260z-280z On sale right now at US$100, it's attractively priced... although you'll probably be out of pocket by Cdn $300 by the time it arrives in Ft. Saskatchewan. If nothing else, though, the photos on their website might give you some thoughts on how to go about making your own. And, before I forget: I've read in the past that the contours of the inner fender sheet metal in the battery tray area can be nicely matched by carving a particular section out of a front fender (if you happen to have a spare lying around that you don't need). Maybe someone else can comment with more detail. Buying the pre-made is definitely plan B. I am going to give it a shot after I figure out the firewall. What’s the worst that can happen ?? Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=4#findComment-568127 Share on other sites More sharing options...
February 12, 20196 yr Author comment_568128 2 hours ago, wheee! said: Ooooooooo! It's coming to my location?! @ConVerTT is located 3 hours south of me. Where the sunshine is.... Sunny and COLD ? Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=4#findComment-568128 Share on other sites More sharing options...
February 14, 20196 yr Author Popular Post comment_568280 Didn’t have too much time today but got the passenger firewall patch fabbed up .... Cardboard pattern .... Traced onto some 20 ga .... f Rough bends on the brake .... And clamped in place ... Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=4#findComment-568280 Share on other sites More sharing options...
February 14, 20196 yr comment_568292 One piece, very slick, that curved corner can be a real buggar to make look good. Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=4#findComment-568292 Share on other sites More sharing options...
February 14, 20196 yr comment_568294 Pfffft... how are you gunna run your coolant lines with clamps in those holes! amateur....! Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=4#findComment-568294 Share on other sites More sharing options...
February 14, 20196 yr comment_568296 Yeah, no kidding. There's no way the hoses will fit. A rookie mistake. Give the guy a finger brake and a MIG and suddenly he thinks he can make stuff. He'll learn. Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=4#findComment-568296 Share on other sites More sharing options...
