240z - fabbing new front rails
ConVerTT
On 2/28/2019 at 5:23 PM, ConVerTT said:
So I got the inner wing stripped and ready to weld in the passenger rail ....DBBCBA68-013B-45A8-8A0E-EDC458DBA7A0.jpeg
Ahhhh - that looks a little better now....
Still some cleanup to do but heading in the right direction ....
so I decided to spend some time on the rad support....
 I re-did the lower support.  This version is a single piece with only two small weld in patches.  I think it will be a little cleaner than my first attempt last week ....
Interestingly the factory rad support is made of 13 different pieces of sheet metal and then welded together.  Not an easy piece to make.  I roughed out three more pieces today ...
Upper gusset braces ...
And the upper cross piece ...
Only 9 pieces to go ???‍♂️....
Edited by ConVerTT
Adding pic
  • Like 3
1 hour ago, Namerow said:
A master class in fabrication.  If we put you and Disepyon together, we'd have a source for truly rust-free Z frames. You do the front, he does the centre, you split to chores for the rear.:beer:
I’m in!
Sadly 147 has been stored like a bottle of wine ~150km away.  I have not had a good look-see ever.  When I opened the hood and saw those joint-like sections and the racing aspects, I figured it had  the front 1/8th replaced.  I'll have to scrape the paint and look for blue under that beautiful copper ?
Edited by 240260280
Mostly welding and grinding this afternoon.  Got the Franken - Fender backing plate welded up (welds get dressed tomorrow ?)....
No new progress on the rad support but threw on some sugar scoops for grins ...
almost ready to move on to the rockers ....
  • Like 3
