10 hours ago, ConVerTT said:
Got the Franken - Fender backing plate welded up
Out of curiosity, are those butt welds throughout, or do I see a few plug welds in certain places?  If you did use plug welds for this repair, what's the rationale?
So ... there are a lot of opinions on butts, versus laps/flanges and plugs versus stitches.  I use all of them depending on the circumstance.  For example: I will almost always lap, plug stitch when attaching “Important” old metal to new metal (like floors to transmission tunnel, or frame rails to the inner fender patch).
I used almost every type on the Franken Fender ....
Been a busy (non-240z) week.  Finally got some fun time at the shop ....
You can guess where this is going ...basically with all the work I’ve put in on this chassis, the following patch job was not going to be acceptable:
Yeah I know no one will see it, but I’ll know....
@disperyon recently covered how to fab these so Just the highlights:
 Laying them out on 18 ga ...
Drilled out with the Blair hole cutter (Amazon)...
A new cryptocurrency?
Dimple dies and the press ....
Rolling the beads with Big Bertha ....
And voila !
I made a mistake marking the lower edge so it is a bit messed up.  Hopefully I can clean it up and finish the passenger side tomorrow.
For those with a keen eye, yes they are deliberately a little different than factory.  I left the rear section boxed so I can run it straight off the edge of the floor kit (Zeddfindings)  to the rear wheel arch.  And at the front I left it a little longer so that it follows the edge of the Zeddfindings floors and left an unfinished piece to tie in to the firewall.
Should look a lot better than the patch (even though no one will see it LOL)
Edited by ConVerTT
Typo
PS ...
Sometimes I hear people ask if the bead is really necessary?  (Probably because it isn’t that easy to roll a bead in 18 ga...)
Well, dimples but no bead ...
Versus dimples with a bead ...
Notice how much stiffer the panel is?  It can basically support its own weight while balancing on Bertha.  So, yes, the bead is important !
52 minutes ago, Patcon said:
I've determined, that's half the battle with metal work
True, and time.  If I had to get paid for this I would starve to death
Edited by ConVerTT
Typo
