December 27, 20195 yr comment_590015 15 minutes ago, ConVerTT said: Awesome -thanks for the info. Both my 240 shells have the same depression as yours so it makes sense that it is from a later car The change would have been due to the implementation of retractable seat belts, that began with the 260z. Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=20#findComment-590015 Share on other sites More sharing options...
December 28, 20195 yr Author comment_590018 32 minutes ago, grannyknot said: Wow, in a garage sale? Who's @zKars garage? Those are unicorns, nice score. Thanks! No. A random guy who lives 5 mins away from me had a bunch of stuff in his garage and basement. More on that later ? Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=20#findComment-590018 Share on other sites More sharing options...
January 3, 20205 yr Author comment_590282 New Years resolution ... better dust control. Enter Dust Booth 2.0 - quad box hybrid down draft /side draft .... Twin 3 speed exhaust .... Twin 3 speed intake ... Fully adjustable to run at negative pressure for sanding and grinding .... or positive pressure for paint work ... ? Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=20#findComment-590282 Share on other sites More sharing options...
January 3, 20205 yr comment_590283 Nice work as expected! Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=20#findComment-590283 Share on other sites More sharing options...
January 3, 20205 yr comment_590286 Beautiful! So negative pressure is the lower fans on pulling air from the booth with the roof fans turned off and positive pressure is the reverse, lower fans turned off and roof fans turned on pushing air into the booth? Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=20#findComment-590286 Share on other sites More sharing options...
January 3, 20205 yr Author comment_590287 3 minutes ago, grannyknot said: Beautiful! So negative pressure is the lower fans on pulling air from the booth with the roof fans turned off and positive pressure is the reverse, lower fans turned off and roof fans turned on pushing air into the booth? Close. Negative pressure with lower fans on 3 and roof fans on 1. Positive with lower fans on 1 and roof on 3. Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=20#findComment-590287 Share on other sites More sharing options...
January 3, 20205 yr comment_590294 8 hours ago, ConVerTT said: Close. Negative pressure with lower fans on 3 and roof fans on 1. Positive with lower fans on 1 and roof on 3. Right, 3 speeds, very versatile. When it's in use I guess you will spin structure around and open the roll up shop door so you can exhaust the dust or paint fumes out the door? Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=20#findComment-590294 Share on other sites More sharing options...
January 3, 20205 yr Author comment_590299 3 hours ago, grannyknot said: Right, 3 speeds, very versatile. When it's in use I guess you will spin structure around and open the roll up shop door so you can exhaust the dust or paint fumes out the door? No. The shop has a draw though exhaust that flows in the same direction - intake louver by the door, exhaust fan on the back wall. I considered hooking it directly to the booth but it flows too much air. Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=20#findComment-590299 Share on other sites More sharing options...
January 10, 20205 yr Author comment_590712 Got a chance to test the painting in the prep booth with some rattle can 2k epoxy primer.... It worked great . You can see where the overspray got drawn into the filters .... Parts came out fine ... welding them in tomorrow hopefully.... Rattle can epoxy primer is ridiculously expensive though. $23 and that took the whole can ...so definitely a laziness tax included in the price. Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=20#findComment-590712 Share on other sites More sharing options...
January 10, 20205 yr comment_590768 Yup, I got suckered into buying a can too. What a waste.... HVLP guns are so easy to use and the results are better. Can't wait to see this project move into high gear! Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=20#findComment-590768 Share on other sites More sharing options...
January 11, 20205 yr Author comment_590793 7 hours ago, wheee! said: Yup, I got suckered into buying a can too. What a waste.... HVLP guns are so easy to use and the results are better. Can't wait to see this project move into high gear! Thanks - I am back in action through April! Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=20#findComment-590793 Share on other sites More sharing options...
January 11, 20205 yr Author comment_590794 Exploded view pics of the rocker assembly ... (I think I promised @grannyknot these about 10 months ago ooops) Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=20#findComment-590794 Share on other sites More sharing options...
