March 25, 20205 yr Author comment_595317 Wall art and 005677 .... before.... After .... and back to hibernation for 005677 ... Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=27#findComment-595317 Share on other sites More sharing options...
March 25, 20205 yr comment_595318 , love the Amateur Z poster...Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=27#findComment-595318 Share on other sites More sharing options...
March 25, 20205 yr Author comment_595319 Thanks! It's very collectible .... Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=27#findComment-595319 Share on other sites More sharing options...
March 31, 20205 yr Author comment_595869 Finally got to try out my new favorite tool - Eastwood's Contour SCT .... I figured this old previously repaired driver's door would be the perfect test panel... before ... Literally 5 minutes later .... Easily could have removed all the filler on the lower door in about two more minutes. I didn't bother since I am planning on re-skinning the lower section anyways ... The Contour SCT rocks - buy one .... Edited March 31, 20205 yr by ConVerTT Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=27#findComment-595869 Share on other sites More sharing options...
March 31, 20205 yr comment_595871 Very cool!Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=27#findComment-595871 Share on other sites More sharing options...
March 31, 20205 yr Author comment_595873 An old mentor used to say "re-skinning a door is part of the basic skill set..." So here goes ... Ground off the edges with a 40 grit flap disk - easy peasy Decided to cut it just below the body line since there will be some filler required here anyways ... Cut it with the air powered body saw and a cutting disk .... Inside is about what I expected .... I didn't have all my PPE available to bead blast the door so I just hit it with shop vac, wire wheel and a bit more Contour SCT .... Next up - fit the door frame to the car. That will be a huge test since the floors and inner/outer rockers have all been replaced. Guess we'll find out if it's all straight LOL.... Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=27#findComment-595873 Share on other sites More sharing options...
March 31, 20205 yr Author comment_595874 Well here goes nothing ... So far so good .... grrrrr - TABCO ???. That will need to be fixed .... Inside looks good! With the fender on ... grrr -TABCO ???? But the rest is workable ... Next up - same drill on the passenger side ... Edited March 31, 20205 yr by ConVerTT Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=27#findComment-595874 Share on other sites More sharing options...
March 31, 20205 yr comment_595875 Stop making us all look bad...Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=27#findComment-595875 Share on other sites More sharing options...
March 31, 20205 yr Author comment_595876 @wheee! I had to get something done ... our mutual friend Rob was making me look lazy with his roadster progress during this lockdown ? Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=27#findComment-595876 Share on other sites More sharing options...
March 31, 20205 yr comment_595877 He’s knee deep in wires Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=27#findComment-595877 Share on other sites More sharing options...
March 31, 20205 yr comment_595878 Wow! Fantastic work. Personally I wouldn't know where to start. Excuse me while I go back to changing oil and cleaning spark plugs. Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=27#findComment-595878 Share on other sites More sharing options...
March 31, 20205 yr Author comment_595879 Thanks Richard! You are too modest? Link to comment https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/?&page=27#findComment-595879 Share on other sites More sharing options...
