  On 3/31/2020 at 4:13 AM, Richard McDonel said:
Excuse me while I go back to changing oil and cleaning spark plugs.
That's exactly what I was thinking. I feel so inadequate!
It’s like grade 3 and making macaroni art for Mother’s Day and Michelangelo is the kid in your class wrecking the curve...
  On 3/31/2020 at 11:11 PM, Patcon said:
Very nice Mike B)
I am missing the Tabco issue?
The outer rockers don't line up very well with the fender or the lower front edge of the door.  I am told this is a common problem with "later" TABCO pressings.
More Contour SCT testing - passenger door ....
Again this door was repaired and heavily mudded by the PO.  I have better doors but let's see if this one is salvageable ....
5 minutes in ...
10 minutes.. tops ...another passing grade for the Contour SCT ...
It turns out to be a very solid door.  I would guess most of the damage is from the PO's prior Bondo repair ...
Not sure if I will end up using this door, but it would be a shame  to throw it out.  I might have a paintless dent repair guy look at it ...
For now I am going to bolt it up to check my work on the passenger side ....
  On 4/1/2020 at 5:03 PM, wheee! said:
Way better than what I started with!
Hmmm - good to know!  I'll look back through your thread to see how you handled it!
Thanks!  Our mutual friend "G"suggested that I get all the panels to primer and then have a mobile PDR (paintless dent repair) guy go over the whole car to minimize the amount of filler needed.  So I might give that a try ...still a few weeks away....
