Fuel Injector replacement 1977 280z
MH77280Z
Hi Friends,
What would be a good fuel injector replacement option and where can I get them? Would appreciate if you can share experiences.
There is one on ebay which is mentioned as stock replacement and is Bosch brand. Let me know.
eBay item number:
202569390132
Those eBay injectors are odd.  They don't list 75-79 which also use the same injector.  They've had the tops machined off so that you can use a hose with a clamp.  I'd stick with the readily available barb style.  A known quantity.
Amazon sells injectors too, of course.
https://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=280z+fuel+injectors
https://www.ebay.com/itm/7-1980-to-1983-Datsun-280zx-Bosch-4-Hole-Spray-Direct-Replacement-Fuel-Injectors/202569390132?epid=26009781693&hash=item2f2a139834:g:zR4AAOxygKZSThrJ:rk:1:pf:0
Edited by Zed Head
21 hours ago, MH77280Z said:
Sure. Did the rockauto ones came with O-Rings?
Also did u change the fuel pressure regulator? should i get that also from rock? there is a OE version on z car parts which is a bit expensive.
Mine came with both rubber seals and a hose clamp.
Here's the thread if you want to read a little.
On the FPR.  I put a fuel rail I built that needed a single inlet like the '78s have.  I'm pretty sure it came from rockauto for $70 something or another.
Edited by siteunseen
